I just replaced the front rotors and calipers today on my 2002 GT. I followed my Haynes manual closely, but apparently not enough. I bled the front brakes as specified until all air bubbles were gone, and started from the passenger caliper and then to the drivers side. When I started my car for a test drive, the brake pedal sunk to the floor when I first applied it and I had no brakes at all. When I was changing the banjo bolts I lost quite a bit of fluid. Maybe I lost too much and need to bleed the entie system. The manual mentioned something about the hydrualic control unit being messed up if you loose too much fluid. Where should I go from here?
