I need definitive heater valve and AC expansion valve answers
  • Thread starter Thread starter PurAU
  • Start date Start date Saturday at 1:12 PM
P
PurAU
St Augustine
Saturday at 1:12 PM
  • Saturday at 1:12 PM
1969 Mustang with factory AC. Early build: (10/1/1968).
With AC to MAX, and TEMP to COLD, I have -11 vacuum to water heater valve. Is valve supposed to be OPEN or CLOSED when AC is on?
Also, without removing, AC evaporator expansion valve is straight and appears to have flanged ends.
Old Air Products, CJ Pony Parts and NPD are in conflict whit what heater and expansion valves I need to buy for replacements.
Compressor/Clutch, condenser, dryer are ALL new. Running R134A. Lowest AC vent temp I can get is 65 degrees.
Please, someone clarify what valves I need to buy.
Thanks
manicmechanic007
5 Year Member
Sep 26, 2017
2,549
720
143
Roy, Utah
Saturday at 5:42 PM
  • Saturday at 5:42 PM
You need to do some diagnosis to determine that
Do you have a 1969 Body service manual with all the diag info?
manicmechanic007
5 Year Member
Sep 26, 2017
2,549
720
143
Roy, Utah
Saturday at 5:44 PM
  • Saturday at 5:44 PM
Last I heard, you couldn't easily get any of that stuff for the Lincolns and T birds
We used to switch them to A/C in the summer and back to heat in the winter
Mcmahst
5 Year Member
Jan 19, 2021
697
277
83
Laguna Woods CA, fort Mohave AZ
Yesterday at 5:58 PM
  • Yesterday at 5:58 PM
The heater hose valve should be closed when you engage the AC function. Those valves are available from multiple sources; my favorite is NPD. If you’ve replaced all of those parts, pulled a vacuum long enough to remove all of the moisture in the system and to verify you have no leaks, and then filled the system with the bright amount of refrigeration, then you have a complete system. Usually, expansion valves do not need to be replaced; they don’t wear.
Now, an R134 system has a lower efficiency rating than an R12 system. Most 134 systems require a much larger condensor in order to gain back some of that loss. But most cars cannot accommodate that. So, to achieve the best results, you have to eliminate that big heat source in the plenum. If you’re not sure on what heater valve you need, call the guys at NPD and they’ll help you.
Good luck.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A
Mustang v6 AC not working - please help
  • Alex3385
  • Jun 21, 2019
2005 - 2014 S-197 Mustang -General/Talk- Jun 23, 2019
JmP6889928
Rebuild Ac Compressor Or Buy Sanden?
  • stykthyn
  • Jun 3, 2014
5K
Fox 5.0 Mustang Tech Jun 3, 2014
jrichker
Who made this aftermarket AC system? (images)
  • sparx
  • Nov 15, 2009
Classic Mustang Specific Tech Nov 15, 2009
dewdrop
D
  • Locked
68 V8 Drum Spindles & Other Stuff "CHEAP"
  • horseballz
  • Apr 16, 2010
  • Suspension
3K
Suspension Feb 4, 2012
USAF46270
U
