Who made this aftermarket AC system? (images)
sparx
369
This is the AC system on my 66. The controls and one vent are mounted in the little box under the ignition switch and the main box with evaporator and two vents is under the glove box. The two components are jointed by a temp sensor line, wiring and the flexible hose.
The compressor is aluminum (made in Japan), by "TAMA".
There IS pressure at the schrader valve so it is possible that this thing works. Car was more or less dead engine when I bought it so no time to test the ac.
I wonder who sold this, it screams Montgomery Wards to me! Many of you may not remember monkey Wards.
So, what I have been thinking is to get a normal evaporator / blower unit that fits right under the dash above the console and get rid of the two boxes. I suppose this all depends on whether the compressor is good or not.
Also I really would not like to cut the console, maybe just remove it all together????
(I have the heater box out for refurb so the evaporator is setting on a piece of wood right now.
sparx
Total of four images, you will have to click on two links.
http://img.photobucket.com/albums/v281/sparx21/IMG_0008.jpg
http://img.photobucket.com/albums/v281/sparx21/IMG_0015.jpg
I have one
Not sure of the maker but I have one. Came on a 70 coupe I bought. Worked for a little while. Evaporator froze up all the time and dripped inside the car. Froze up on the OUTSIDE of the box.
I installed an OLD AIR unit in my 65 with console. vents come out at the side and around the console. Looks good and works good. About $1000 and you replace existing heater box with new set up.
