I need definitive heater valve and AC expansion valve answers
1969 Mustang with factory AC. Early build: (10/1/1968).
With AC to MAX, and TEMP to COLD, I have -11 vacuum to water heater valve. Is valve supposed to be OPEN or CLOSED when AC is on?
Also, without removing, AC evaporator expansion valve is straight and appears to have flanged ends.
Old Air Products, CJ Pony Parts and NPD are in conflict whit what heater and expansion valves I need to buy for replacements.
Compressor/Clutch, condenser, dryer are ALL new. Running R134A. Lowest AC vent temp I can get is 65 degrees.
Please, someone clarify what valves I need to buy.
Thanks
The heater hose valve should be closed when you engage the AC function. Those valves are available from multiple sources; my favorite is NPD. If you’ve replaced all of those parts, pulled a vacuum long enough to remove all of the moisture in the system and to verify you have no leaks, and then filled the system with the bright amount of refrigeration, then you have a complete system. Usually, expansion valves do not need to be replaced; they don’t wear.
Now, an R134 system has a lower efficiency rating than an R12 system. Most 134 systems require a much larger condensor in order to gain back some of that loss. But most cars cannot accommodate that. So, to achieve the best results, you have to eliminate that big heat source in the plenum. If you’re not sure on what heater valve you need, call the guys at NPD and they’ll help you.
Good luck.
