I Need Help Putting Tragically Modded Car Back Together
Twitch88
I just bought my mustang off a guy who has done a lot of work to the car and I think a lot of bad. I have hooker header running exhaust all the way back with no 02 sensor ports no cats ,nothing. I lways have the check engine light on and cant even get a sticker for the car. First gear is soo damn slow and raises the rpms soo high i think the car is gonna blow up on me. the car came wiht a sct tuner that has been noted to be out dated and none of the tunes on there work . I dont think the tuner was for this car. for a v8 i think the car should have some heart. PLEASE someone e-mail me at [email protected] and tell me what i should do. the idle hangs and i already replaced the iac. just bought a new tps but dont think that is the issue. i know nothing about mustangs and really need some help.
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,807
499
164
Houston Texas
Just wondering. What model year Mustang are we dealing with anyway?
+1 on the need of an ODB2 reader. Here's some information on an affordable Windows based solution.
ForScan ODB2 scanner w ELM327 USB
https://www.stangnet.com/mustang-forums/resources/forscan-odb2-scanner-w-elm327-usb.57/
I'm assuming this is an automatic. Is the speedometer accurate? An inaccurate speedometer can mess up the automatic shift points. But if looking for an educated guess it takes time for an automatic to shift gears. The PCM must call for the shift BEFORE it is actually needed. When lower gears are used the RPM's will climb faster. Therefore the shift points will need to be lowered to account for the faster RPM rise so that the shift will actually occur at the correct RPM's/time.
Here's some information on how to trouble shoot Idle/IAC issues.
Troubleshoot IAC idle problems 1996-2004
https://www.stangnet.com/mustang-forums/resources/troubleshoot-iac-idle-problems-1996-2004.13/
Being new to Mustangs having access to a Ford service manual and wiring diagrams could be a huge help. If interested in getting a copy for yourself I maybe able to help. PM if interested.
OBTW, if this is is a 1996-1998 these Mustangs really don't have a lot of "grunt" by today's standards.
Mattstang04
1,144
141
104
St. Louis, MO
Have mercy on you for trying to correct another man's "hot rodding". Re-virginizing a car is a daunting task. The old cars, before miles of wiring played an integral roll in vehicle function, They were easier to put back to stock. All the gadgetry and electronics of modern or even semi-modern cars complicates the "un-screwing" of them.
Thread starter Similar threads Forum Replies Date
M Need help putting big valves in 65 289 heads Classic Mustang Specific Tech 0
L Need Help Deciding Type Of Cam To Put In 65 Stang 1965 - 1973 Classic Mustangs -General/Talk- 6
S New Engine Put In 2000 Mustang Gt, Need Help! SN95 4.6L Mustang Tech 8
boostfrk Engine Need Some Help Putting Smog System Back On Fox 5.0 Mustang Tech 5
D Need Some Help Putting Together My 50 Fox 5.0 Mustang Tech 1
2 Putting dash back in , need wiring help 1994 - 1995 Specific Tech 7
all1knew need to put a windshield in, help please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
S Need help putting rockers in 331 Fox 5.0 Mustang Tech 1
8 need help putting starter solenoid back on 1985 5.0 after having it off for 2 years Fox 5.0 Mustang Tech 3
fawcett Putting the Stang back on the Streets-Need help finding parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
J HELP need to find the least expensive way to put AC in a 68 Mustang Classic Mustang Specific Tech 5
T New 4v DOHC engine. Need help putting it in! Please help SN95 4.6L Mustang Tech 2
95CobraStang Putting 5.0 into a classic- need help weighing in on choices...thx 1994 - 1995 Specific Tech 3
fawcett Stupid: Went to put brakes back on, need help asap! 1994 - 1995 Specific Tech 5
KStrike155 Going to put in fuel pressure gauge with my KB... need a little help. SN95 4.6L Mustang Tech 4
M need help just put suspension on and it doesnt look right SN95 4.6L Mustang Tech 11
6 Need help on putting 93 5.0 heads on 289 rocker trouble? Classic Mustang Specific Tech 4
PeteyAce need help with putting in new gears and rebuilding traklock Fox 5.0 Mustang Tech 10
5LugFoxFanatic Need help picking which engine to put into my 86.... Fox 5.0 Mustang Tech 2
B looking to put a blower on my 89 notchback need help Fox 5.0 Mustang Tech 4
6 need help anyone put a dvd player in a 65 stang? Mustang Sound & Shine All 1
S Engine Need help: heater hose routing for 92 2.3 liter 2.3L (N/A & Turbo) Tech 0
T First fox... she needs help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
C Engine Help diagnosing a whine at low gas pedal pressures - 1998gt SN95 4.6L Mustang Tech 0
Kylor Need help pricing 2000 Roush Stage 2 What is it Worth?!?!? 11
0 Need Help Transmission Swap 2005 - 2009 Specific Tech 1
Cheapskate207 Brakes Need help with Brake ID Fox 5.0 Mustang Tech 12
Wayne Waldrep Engine Trouble with the old pile...I mean car. Need some help. Fox 5.0 Mustang Tech 7
YadiStang Need help with my 1969 oil dipstick 1965 - 1973 Classic Mustangs -General/Talk- 8
D 1995 mustang gt 5.0 Need help please! 1994 - 1995 Specific Tech 8
M Need help tuning megasquirt with kenne bell supercharger Digital Self-tuning Forum 5
D Fox Need help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
1 Engine NEED HELP PLEASE!! Fox 5.0 Mustang Tech 4
atey950 89 5.0, Trick flow stage 1 h/c/i, Megasquirt pnp novice needs help Digital Self-tuning Forum 4
Silver Bullitt Desperately need electrical help! 2005 - 2014 Specific V6 Tech 10
Jetzv8 2015 mustang led license plate wiring help needed 2015+ (S550) Mustang -General/Talk 0
wbrockstar Help Needed To Identify Wiring Component On Hanger At Fuel Pump 1994 - 1995 Specific Tech 0
M Engine Need help on belt with V3 Fox 5.0 Mustang Tech 4
O Need help..ASAP! 1996 - 2004 SN95 Mustang -General/Talk- 2
ShadowBlueGT Electrical OEM stereo reinstall wiring help needed! Fox 5.0 Mustang Tech 2
ChuckFoxLx Engine Need help and tips Fox 5.0 Mustang Tech 9
L I'm New, Need help. please. SN95 V6 Mustang Tech 1
A Engine Need Help Finding a Part Classic Mustang Specific Tech 1
T Need Help With Wiring Fox 5.0 Mustang Tech 2
Blueharry Need Help picking a New springs and shock! 1996 - 2004 SN95 Mustang -General/Talk- 0
5 NEED ADVICE FROM COMMUNITY MEMBERS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
R 2013 Mustang GT pad and rotor change, need help. 2005 - 2014 S-197 Mustang -General/Talk- 4
Keionte HI, All Need Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 112
Conformist Installing '98 Mustang v6 Fog lights (Help needed) 1996 - 2004 SN95 Mustang -General/Talk- 3
D Need Help with wiring an 87 GT Convertible Radio Fox 5.0 Mustang Tech 30
