I NEED HELP ..BEFORE I RUN AGAIN.
i got a 351w ,,just ran this weekend,,i made 3 10s runs back to back on 175 shot of nos..after i got home i went to check plugs ,,eveything looked great..i did a compression test ok,,i got 180psi on 6 cylinders,,the other 2 i have 160..i did leak down test also,,the one that was low had the least amount of leakage on one,,the other was like the rest ,,i have between 3% to 7% leakage acoss the board,,i have a soild rooler cam ,an adjusted the valves but made no difference,,,motor runs fine ,now im afraid to run it,,should i be conserned ????or should i just run it again next weekend??what to you'll think.is wrong,,if anything??im going to spray a 250 shot on it ...this week ...i ran a 10.59@130mph,,trying to break into the nines,,please help..
