Sorry about the caps lock in the title...
This is a stock block with everything else in it aftermarket and brand new (306)
1. I need to prime my oil system, and was told i can do it with a cordless drill, and a long 1/4" extension.
is this the best method? I have seen the oil priming rods, but im broke, and just need to get it running as cheap as possible.
(how long do i need to spin it to ensure its all primed?)
and if it takes me a few days to get the distributor in, will i have to prime it again, or is once sufficient?
im going to put the distributor in. I need a very detailed "how to" and pictures would be awesome! I am running a carb, and was told that if i have it 180* out, it will backfire, and blow out my power valves, so im trying to avoid that.
Once i have that in, and run the plug wires, ill just about be ready to fire the thing up.
Any advice on anything i should triple check before i turn the key?
