I need Help with my 347 stroker
tavito_monroy
Hi friends, how are you, I need some help with my 77 coupe, I put a 347 stroker kit on my 77 and I want to now if someone can help me. I need tips, inromation, etc, about how can I get max benefit and HP of my 347 stroker, here there are de engine´s specifications:
HEADS:
* 58cc combustion chamber
* 180cc intake runners
* Intake valve diameter:1.94 in.
* Exhaust valve diameter: 1.60 in.
* 3/8 in. screw-in studs
* Valve springs: 1.250 in. dual, 100 lb. seat pressure
* Max lift: .560 in.
* For hydraulic flat tappet cams only
CAM:
Brand: Competition Cams
Product Line: Competition Cams Xtreme Energy Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,000 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 286
Advertised Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.523
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.523 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: No
Grind Number: FS XE274H-10
CARBURATOR:
Road DeamonJr. 625cfm
INTAKE MANIFOLD:
Edelbrock Performer RPM
HEADERS
Compression Ratio is 9.6, in the ignition system I only have a MSD Blaster 2 Coil, and 9mm Ford Racing Spark Plug Wires the other are stock. I want to put on an MSD 6A Ignition Box
Do NOT run this engine until you change the valve springs to match the camshaft. Those springs are NOT near enough for your fast ramp XE lobe cam. You'll need 120-130lbs on the seat I would guess. Your cam sheet should have the recommended springs and installed height.
Once you do that I would start around 34* total timing. Im not a carb person so I don't know what to suggest for that.
