I need help with Timing
neil_home
37
Connecticut
I have what I thought was the Duraspark III but during the search I read someones note with a part number the same as mine that was called the Duraspark II. Anyway it is a 5.0 with the crank trigger. There is a fixed (not adjustable) distributer with just the rotor inside. I thought from the reading I had done that the adjustment for the rotor may change the timing. My emmisions were just a hair high on the HC and CO. I did a tuneup,air fiters. and fixed a hole in the air pipe going to the cats. I checked for vacuum leaks and filled it with high test gas. It failed exactly the same way. Just a tad high on HC and CO. The readings on this car have been the same for years. The limits are lower.Its an 83 5.0 TBI.Does anyone know how to adjust the timing. It idles at 20 degrees advanced. I read it should be 10 and that that might put me under on the emissions. If you know how to adjust this or have any other ideas please let me know.
Thanks in advance, Neil
Timing
The rotor change did not change the timing. It is at 20 degrees. Moved it both ways and rechecked no change. Then disconnected the battery and adjusted again. No change. The book says it onlt needs adjusting to make sure the spark is in the correct position in the cap. I can't find anything else adjustable. On the car or in the books.
to start a duraspark 2 is a carbed car or TBI right? Even if the crank sensor does not move then the distribtor has to move. Also you have to have some sort of advance system, did you set the timning with out the vacuum advance hooked up?
The car is a TBI. There is no vacuum advance. I did not notice any mechanical advance in the distributer either. The distributer is keyed and will not move. The crank pickup looks like it is stationary in the front cover. But I couldn't see it very good (air pump in way). The timing ring looks to be pressed on the vibration damper. I can get the part # of the ignition box if that would help. I am at a loss for ideas.
Neil
