Fox I need help with upgrading multi switch on column
motel6tom
Did a 90 dash swap into m 85. Bought ron francis wiring. I wanted to use my original steering column but the wiper switch won't clear the cluster. What do I do? Can I just swap the switches 2 for 1? I don't want the airbag wheel with no tilt. Please help.
Easy button is to get an 87, 88, or 89 tilt column. You will then have to make a tilt column work with a non tilt dash but there are several threads here on how to do that.
Someone may chime in and have a way to make your 85 column work.
