i need help
hello everyone i need help i cant tell if its a miss fire or a air fuel mixture thing but i just changed my headers to long tubes and put in a cold air intake but when im driving once it hits 3k it sounds like its dropping cylinders but once i rev it past it it’ll run and drive fine its a 94 mustang Gt 5.0. i need to know asap
Your car is OBD-1.
You can use a cheapo scanner from Amazon or use the method below:
Reactions: DadLife0724
Your car is OBD-1.
i actually already own that obd reader and the obd one doesn’t get anything to it
Sometimes if you rotate the MAF to a different position it helps. Loosen the clamps that hold the tubing to the MAF. Rotate the MAF 90 degrees if you can and retighten the clamps. Give it a try and see.
If you can’t rotate the MAF, you can always put the factory air filter stuff back in and see if the problem goes away.
By the way, the factory setup is already a cold air setup. You probably gained nothing by removing it. Is the new filter exposed in the engine bay?
Also, changing to long tube heaters involves O2 sensor being further from its stock location and typically involves wiring extensions. How did all that go? Double check all of that and make sure wire connections and wire securing is good.
If I were you I'd take the CAI off and go back stock to see if it clears up. The electrical problem you have needs to be sorted out though. Like stated turning the maf may help.
i figured it out cylinder 4 is misfiring and im trying to figure it out its not the distributor cap or rotor cs i js replaced those and they dont look bad and i js replaced all the wires after this happened so idk why its doing it. i hope its not a bad cam or something cause i was hearing an intermentant clicking above cylinder 4
Just out of curiosity, how did you discover #4 misfiring. Is that cylinder not firing at all or is it randomly misfiring?
