I need Manual to Power window Wiring help!!!!
I own an 88 LX that has power mirrors and locks, but manual windows. Purchased 2 doors from another 88 lx with power everything. Does anyone have any information or know where I can get a window wiring diagram??? Any insight would be greatly appreciated. Thanks!!! By the way if anyone is looking for 2 manual doors in great condition, let me know. Thanks Again! :stupid:
I hope you got the complete harnesses from the doors into the car under the dash. There should be a connector at the ends of the door wiring boot. If the wires were cut, then it will be much more of a PITA to hook it up since you will have to wire all the wires together to another connector, or hard wire them under the dash, which would be a pain.
If you have the connectors, then it is just a single wiring harness that goes from door to door and plugs into the main harness with two wires, a pink and a black with white stripe one, right in the drivers side kick panel.
The wires from each door just connect to the same color on the other side, so you can just connect them if you need to.
If you use the stock power wiring, you will need a power window circuit breaker for the fuse box.
Here are some wiring diagrams:
http://statefilingsoftware.com/pictures/doorlockscan.jpg
http://statefilingsoftware.com/pictures/doorlockscan2.jpg
