Drivetrain I Need Some Flywheel help/knowledge please
Alykai
Missouri
So I'm trying to get my engine and tranny back in my car. I got the flywheel bolted down, and started installing the clutch and pressure plate. The pressure plate does not match up to any of the dowl pins in the flywheel, close but no match. I thought maybe I got the wrong clutch, but the clutch kit was correct. The only other thing I can think of, is if it is the wrong flywheel for my car. I got the car as a roller, but with the engine and tranny and a crap ton of foxbody parts. I assumed the flywheel I had was the right one, so I decided to have it resurfaced and use it. Now, here's my question(s). When I measure the flywheel from top tooth to bottom, it measures 14" in diameter. Everywhere I have looked for flywheels for this car, they say the flywheel is 10" in diameter. Can anyone tell me if I am right or wrong with this assumption please? For the record, its a factory 302, with the factory T5 tranny, all stock.
Thanks,
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,313
9,616
224
Massachusetts
Photos of the flywheel? Any identifying markings,
10” refers to the diameter of the contact surface for the clutch disk. Should actually be around 10.5” or so. Actual flywheel should be 12-14” ish
Alykai
Missouri
I will try to get a pic of it soon. That is what I was wanting to know though, basically, how to measure it. Thank you very much!
Mstng93SSP
You have a nice rear end there Dave.
2,351
184
Mililani, Hawaii
Flywheels are cheap. If you have a clutch kit for an 87-93 5.0 Mustang go buy a new flywheel for an 87-93 mustang 5.0. Easiest solution. I know you can get a new one for around $75.
Chris
Alykai
Missouri
Just wanted to let everyone know, it was the flywheel after all. I got a new one that the pressure plate fits perfectly, and it is a lot smaller than the one I was trying to use. Like I said earlier, this car basically came in pieces like a giant puzzle, and that was the only flywheel that was in with the parts. Thanks to everyone that gave me some feedback on it all!!!
Admin Dude
Jan 4, 1985
28,696
10,661
224
Box behind Walmart
www.stangnet.com
Heh... I was typing as you were.
Thread starter Similar threads Forum Replies Date
J Drivetrain need flywheel help. been seaching allday. SN95 4.6L Mustang Tech 3
1bad67sbf need some balancer and flywheel help Fox 5.0 Mustang Tech 8
B Mixing Clutch and Flywheel Brands? REAL HELP NEEDED! 2005 - 2009 Specific Tech 0
2 Need a flywheel dowel pin asap. Please Help! SN95 4.6L Mustang Tech 0
S need help on flywheel 1994 - 1995 Specific Tech 2
5ohhh Need Flywheel Help!!! c4 guys inside! 1994 - 1995 Specific Tech 1
2004mysticobra Need flywheel resurfaced ASAP! HELP Regional Forums and Event Information 0
B Need some help with a flywheel and clutch Fox 5.0 Mustang Tech 3
88 Fox GT Need help identifying this flywheel. Classic Mustang Specific Tech 6
TweekedGT Need help, clutch, tranny, flywheel.... SN95 4.6L Mustang Tech 2
1991vert Need Flywheel Help Asap Fox 5.0 Mustang Tech 3
B Need help with flywheel Fox 5.0 Mustang Tech 3
A 89 5.0HO flywheel specs help needed !!!??? Fox 5.0 Mustang Tech 3
T need help with flywheel SN95 4.6L Mustang Tech 3
J I need help with a flywheel Classic Mustang Specific Tech 2
I need some flywheel help Fox 5.0 Mustang Tech 7
G Flywheel he!! need help Fox 5.0 Mustang Tech 9
W need help on flywheel Fox 5.0 Mustang Tech 0
N Engine 302 Block to flywheel distance needed Fox 5.0 Mustang Tech 0
H 1966 Mustang 289 flywheel info needed Classic Mustang Specific Tech 7
T Flywheel/clutch Need Replacing? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
slam_154 Need Advice Choosing New Clutch+flywheel Spec Vs. Exedy 2005 - 2014 S-197 Mustang -General/Talk- 0
P Drivetrain Need A Flywheel - Any Suggestions? 2000 Gt T45 SN95 4.6L Mustang Tech 2
B 2003 SVT Needing Flywheel - What do I get? SVT Tech Forum 2
J clutch and flywheel info needed before i order SN95 4.6L Mustang Tech 4
W Flywheel questions need your assistance. SN95 4.6L Mustang Tech 2
K Time For T-56 kit, lightwheight flywheel, and a hydralic clutch kit Need Opinions!!! 1994 - 1995 Specific Tech 3
SinCityVogel I need clutch and flywheel 2005 - 2009 Specific Tech 11
5spd GT Need some quick sizes of bolts: Transmission bellhousing, pressure plate, flywheel.. Fox 5.0 Mustang Tech 7
N Need advice on flywheel Fox 5.0 Mustang Tech 10
Stang007style Need a Clutch Kit/Flywheel/driveshaft setup 2005 - 2009 Specific Tech 11
vikingpower New flywheel need balancing? Fox 5.0 Mustang Tech 1
O Doing my t56 Swap, Do i need a new flywheel SN95 4.6L Mustang Tech 4
R Billet Flywheel? needed? Fox 5.0 Mustang Tech 2
M which counterweight for Spec flywheel? Need 28oz Fox 5.0 Mustang Tech 2
W Anyone need a new Flywheel? Regional Forums and Event Information 1
R SFI bell housing or flywheel needed? Fox 5.0 Mustang Tech 12
speadfreak 351w swap....which flywheel needed? Fox 5.0 Mustang Tech 3
K How much for clutch/flywheel install what else do i need? SN95 4.6L Mustang Tech 10
F Just upgraded now i need some advice on this flywheel and clutch SN95 4.6L Mustang Tech 0
N Need Flywheel Resurfaced 1994 - 1995 Specific Tech 8
Killercanary In need of TQ specs of flywheel and pressure plate 1994 - 1995 Specific Tech 6
J Need a 28 oz flywheel...anyone? Regional Forums and Event Information 4
S Crank/Balancer/Flywheel balanced? Stroked? Aftermarket Flywheel? Answers needed! Fox 5.0 Mustang Tech 5
Mr GT 02 Is new Flywheel Needed? SN95 4.6L Mustang Tech 2
6 I used a smaller flywheel on the swap what else needs to be changed. Classic Mustang Specific Tech 4
Ernad When do I need to change the flywheel? SN95 V6 Mustang Tech 3
D INTERIOR PIECES NEEDED The Welcome Wagon 0
D Suspension Griggs rear set up on my 1991 GT, need help with set-up Fox 5.0 Mustang Tech 1
mustangpauly 351w swap need help will not idle Digital Self-tuning Forum 8
