I need some help identifying spindles
  • Thread starter Thread starter oddlife
  • Start date Start date Jan 23, 2006
oddlife
  • Jan 23, 2006
I have a 1965 Mustang that I'm converting to a V8. It has power steering and uses the drum V8 spindles with a disc conversion. However, the spindles I got from ebay have too big a hole for the tie rod ends to connect. The tie rods are basically loose in the spindle hole. My guess is that they are from another year, but I don't know which one. Here is the Ebay page, the guy clearly says 1965 Mustang http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8024649384
I have an old bent spindle from a car I know is a 65-66 mustang. And they have subtle differences. Obviously the biggest is the size of the hole for the tie rod ends. Everything else fits fine. The wheels are on the car.
So my big question is if I need to find a correct set of spindles, or does anyone know of some tie rods I can buy that will work? Keep in mind I have power steering so the left tie rod set is different from the right.
Thanks in advance!
oddlife
P
Protowrxs
93
Oklahoma
Jan 23, 2006
  • Jan 23, 2006
Although some of the pic links are still broken (Trinity needs to fix those sometime), this is a good link for Mustang spindle info.
http://www.trinitysmustangs.com/Spindle_recognition.htm
What is the casting number on the spindles? Should be a C5xx for a 65-67 from what I gather.
Edit: Those might be more early Falcon than Mustang?
-Stephen
oddlife
  • Jan 23, 2006
-Stephen
THx for the link, I'll check it out. They could be from a Falcon, in which case am I out of luck? I thought they were interchangeable.
P
Protowrxs
93
Oklahoma
Jan 23, 2006
  • Jan 23, 2006
Not sure if you're out of luck. I would imagine there are tie rod ends that would work but you would want to make sure the rest of the geometry is the same as a '65.
What is the ID of the bottom of the tie rod end?
Just for reference I have a '69 and '70 set on the bench.
'69 = 1.545"
'70 or '71 = 1.585"
Note those are with a dial caliper so they are not exact.
-Stephen
oddlife
  • Jan 23, 2006
Shoot, I'm at work
I measured when I was working on them yesterday, but didn't write it down. I'll get the measurement tonight. Thanks for you help so far
'69 = 1.545"
'70 or '71 = 1.585"
-Stephen
oddlife
  • Jan 24, 2006
OK, I've taken down a few measurements and casting numbers:
ID for the bottom of the Tie Rod is 1.53125""
OD for the top of the hole in the spindle is 0.5"
OD for the bottom of the hole in the spindle is 0.5625"
So the taper is a difference of 0.0625"
And of course those sizes are too big for the tie rod shaft that needs to fit in there.
The casting number is C60A-108F 121 Although I couldn't read the last letter very well. I think it was an "F" though. I'm going to try to find some more info on that number if I can. So far I haven't found anything.
Thanks again for all your help
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Jan 24, 2006
  • Jan 24, 2006
Those look a little different then mine. 66 V8 Manual.
The back plate on mine on top is square.
A
Applejack
32
White Lake, MI
Jan 24, 2006
  • Jan 24, 2006
If I udnerstnad the interchange correctly, the '65 V8 and I6 tie rods are differnet sizes. I'm not sure if you'd have to change the inner and sleeve as well, but I'm sure once you got outers it'll be obvious.
H
havack
351
Memphis TN
Jan 25, 2006
  • Jan 25, 2006
If you are trying to put this into a I6 car and it has the original steering stuff, then the tierod ends will be too small. ALL of the steering stuff will need to be swapped out.
oddlife
#10
  • Jan 26, 2006
  • #10
Thanks everyone for your feedback. I found Mustang Steve using the link Protowrxs provided above. He is very knowledgeable and told me my spindles are '67 mustang. I'm going to get some '65 spindles from him. And the Ebay dude will take back the '67 spindles since he had it all wrong
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
