I need traction help!!!
Redfire03GT said:
Panhard Bar and Torque Arm go a long ways when looking to improve rear traction. Get that out of the way, then get some quality lower control arms and you're on your way to a very stout set up.
:rolleyes:
that's not going to help the bind in the control arms.
LCA's, UCA's and a solid swaybar before you look at a PHB/R.
tomustang said:
:rolleyes:
It may not stop bind, although, with a Torque arm, in most cases, the upper control arms are eliminated, correct? Besides the PHB, T/A and LCA's, the sway bar is a good recommendation. But why buy UCA's if the T/A replaces it and does a better job? If I'm mistaken, then I'm sorry but, as far as I know, it's a far superior set up over our current 4-link design. :shrug:
Well in order to run a TA you have to have certain specs ie: subframes, PHB, choosing gears. UCA's are eliminated correct. but you need to take baby steps in order to reach a TA setup even though you don't really need a heavy-duty type suspension for most driving consitions, that's why i'm saying stay with the 4-link beef it up and if you want more then you can upgrade after that. start with the basics
