I needs more power
  • Thread starter Thread starter jake_1977_77
  • Start date Start date Mar 13, 2007
J
jake_1977_77
33
Columbus, Georgia
Mar 13, 2007
  • Mar 13, 2007
Hey fellas, I have a 1992 GT 5.0 I am looking for more power, I just bought the car, the guy I bought it from said it is now a 306 and has an E303 cam, the SMOG has been removed, I do not think there are underdrive pullies on it yet (how can I tell?) I was looking into getting a V2 supercharger kit, but that is $2,800!!!! I would appreciate it if you guys could give me some input with some power add ons!!! Also I have 3:73 gears and an aluminum drive shaft. Also what is the best strip street tire I can get? I roast them in 1st and 2nd. I believe they had a NOS setup on this car as their is a plugged hole in the hose tight in front of the throttle body. I bought a kit for my 2000 GT I just sold, will that fit on my 1992? Last thing my air filter is like a foot long and is like laying on the valve cover, should I change this to go into the fender? Any help is greatly appreciated!!! I love reading all of your inputs throughout everyones posts!!!! oh yea how can I add a pic of my car to my posts?:SNSign:
LB0193
171
IL
Mar 13, 2007
  • Mar 13, 2007
UM...well I understand that a blower is expensive, but if you want to go fast you got to spend money, NOS is cheap way to make power if you want to go that route, also does your car have stock heads intake, if so get some Trickflow heads and an intake, 24 pound injectors, mass air, tb, to with that E-cam, I also would put the filter in the fender, there is so many things to do with these cars its up to u, but a h/c/i car with a blower or nos will move and put a smile on ur face
gcwh02
515
pottstown, PA
Mar 13, 2007
  • Mar 13, 2007
yea gotta spend money to go fast, $2500 bucks after awhile seems like chump change... Yea you can find junkyard upgrades with the gt40 heads and TB's and MAF's but that only takes you so far. If you wanna go fast, save your money and buy some aluminum heads and a good intake. Then the blower and you got yourself a nice street car
carnutz
12
  • Mar 13, 2007
hay dude put lower gears in the rear 3.5 or 3.75 for road 4.11 for drag
you will see a big dif.
also check the intake. TB 70mm or 75mm cold air, new intake if you have a stocker on that nice motor.
next would be new h pipe ... and hotter coil
then think about power adders
hope that helps.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 13, 2007
  • Mar 13, 2007
Move the intake air pickup back to the fender. Sucking in hot air from around the engine is a cause of idle and off idle surge and stall problems. The stock airbox is better than what you have, and better than most CAI kits.
J
jake_1977_77
33
Columbus, Georgia
Mar 13, 2007
  • Mar 13, 2007
thanks fellas for the tips, where is the best place to get trick flow heads? are those aluminum? also the throttle body and air intake. would summit or jegs be a good place for the money? what kind of cold air kit should I get? any tips on street tires for better grip at take off? anyone that has advice or tips please let me know, thanks in advance!!!!
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
