  • 1994 - 1995 Specific Tech
I ordered my BBK shorty equal lengths today yay!
  • Thread starter Thread starter V8302stangs
  • Start date Start date Aug 9, 2005
  • 3
First Prev 2 of 3 Next Last
V8302stangs
211
San Jose, CA
Aug 9, 2005
#21
  • Aug 9, 2005
  • #21
I actually do have gears, 3.73s as well as a few little things mainly including the usual flowmasters and off road h pipe, an MSD 6al, and upgraded to a 255lph when my old pump went out. Everything throttle body down is staying stock until I am ready to rebuild the entire motor, I don't see much purpose in messing with internals on a motor with 161k on it, but seeing as though I wouldnt want to drop in a new long block without headers, it's something external I can do without putting much work on the motor. I'm not worried about having the car out for a few days (something I planned) since I have a restricted license at the moment anyways (due to unrelated circumstances) and figured now is the time to get things like this done, plus the fact that I will have to swap my h pipe off and back on to get smog done next week anyways.
DFG 5OH
1,341
Louisville, KY
Aug 9, 2005
#22
  • Aug 9, 2005
  • #22
your motor will be fine. Go ahead and throw some heads on it
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 9, 2005
#23
  • Aug 9, 2005
  • #23
Here wrench away
http://www.centuryperformance.com/jbaheaders/install15.htm
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Aug 10, 2005
#24
  • Aug 10, 2005
  • #24
I had equal lengths for years with the smog crap on. It pretty much sucked on the install and sucked on spark plug changes. Honestly they won't make but 1HP if that over unequals. Not worth the time in effort in my opinion. Not my car do what you want, just my two cents. I also had them in chrome. They will be blue in a few hours.
I'm doing Bernie MAC cermamic Long tubes this time around. I learned my lesson with chrome.
Black95GTS
1,644
Marlborough, MA
Aug 10, 2005
#25
  • Aug 10, 2005
  • #25
Grn92LX said:
yay you just bought a part that won't make a lick of difference on a bolt on car Can you cancel your order to save the cash? Not trying to flame, its just that shorty headers are such a waste of cash on a bolt on level.
You are so right its not even funny. I can't tell you how many times I wish I had spent the 400 bucks on 4.10 gears then on these crappy (but nice looking) headers.
Make sure to use the Stage 8s, and plenty of Mr. Wrench on the old bolts, mine were a PITA to get loose.
I
igotyofire
774
Southern California
Aug 10, 2005
#26
  • Aug 10, 2005
  • #26
Grn92LX said:
Wasn't meant to be harsh, hence the " " Stock headers are perfectly fine at a bolt on level. Not that I know what i'm talking about
i think that with an offroad pipe the headers become a bottle neck...atleast on the iron gt40 heads anyways, not too familer with E7s
94opalgt
358
AKRON,OHIO
Aug 10, 2005
#27
  • Aug 10, 2005
  • #27
stock headers are garbage,they are not fine for a bolt on motor.heck they arent even fine for a stock motor they're junk.get them off and get the new ones on,no matter if they are equal or not they will be 100% better than the stock crap thats on it.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 10, 2005
#28
  • Aug 10, 2005
  • #28
But the stock h-pipe is 75% of the restriction in the stock exhaust system. Ditching that is what matters most.
Scott
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 11, 2005
#29
  • Aug 11, 2005
  • #29
Scott
Especially if you get ones without cats.
RC
T
The NJ Exile
81
Northern VA, Philly & Northern NJ
Aug 11, 2005
#30
  • Aug 11, 2005
  • #30
What all this crap about taking a whole weekend..B.S. You can have you headers on in one day.
1. unplug battery ( while under hood, spray down all the header bolt with WD40, Mr. Wrench, Break free..What ever)
2. Jack up car, and support on Jackstands.
3. Drop the H-pipe ( make sure to unplug the O2's)
4. Pull off the intake track, Plugs and wires
5. unbolt old headers.
6. scrape all the old gasket crap off the head.
7. bolt new headers in ( The drives side is a PITA, passange side drops right in).
Don't forget to check for leaks. Start the car, let it run for 5 mins. and then let it cool, retighted all bolts.. You done.
I did mine on a Saturday, I started @ 7:30am was done by 2:00pm..
JJ95GTID
1,141
Phoenix, AZ
Aug 11, 2005
#31
  • Aug 11, 2005
  • #31
The driver's side goes in from underneath. Unbolt the steering shaft to make things easier to install the new header.
To get the passenger side header in I had to unbolt that side of the engine's motor mount and lift the engine a little bit. I put a piece of wood between the oil pan and floorjack and raised it slowly about 2". Then you can slide it into place from up top between the engine and strut tower.
BUT, now that I have done a head swap this is what I wished I had done on the passenger side. Remove the serpintine belt. Remove the belt tensioner assembly. Then remove the bracket holding the alternator and air pump(smog) as a unit. Belt tensioner has to come off first because it covers one of the bolts that hold the bracket onto the head. With all that out of the way you can easily install the passenger side header without lifting the engine.
Black95GTS
1,644
Marlborough, MA
Aug 11, 2005
#32
  • Aug 11, 2005
  • #32
Do you have flow numbers or any kind of evidence to support that? Are stock headers an actual bottle neck when coupled with stock heads? I highly doubt it. The stock heads outflow those headers? (They're actually manifolds; I dont think I would actually call them headers).
Summit states that you can make 8-15 hp with the headers. Converted to rwhp via 17% drive train loss you get 6.6 - 12.45. And we know that you're going to be more then likely at the low side due to the weak stock heads / Summit trying to pump up sales.
I'm not trying to rain on your parade, but I've done EXACTLY what you're doing right now, and if I could do over again I would have done it differently. Thats all.
- adam
T
The NJ Exile
81
Aug 11, 2005
#33
  • Aug 11, 2005
  • #33
Damm.. I put both side in from the top.. I didn't even remove the sterering shaft to do it... Hell I didn't even loosen/ jack up the motor...
JJ95GTID
1,141
Phoenix, AZ
Aug 11, 2005
#34
  • Aug 11, 2005
  • #34
Did you install equal lengths or unequal lengths? E/L headers are definately more difficult to fit than U/L headers.
CManT1914
3,172
Killeen, Texas
Aug 11, 2005
#35
  • Aug 11, 2005
  • #35
Actually they are headers on our cars. The modulars have manifolds.
T
The NJ Exile
81
Aug 11, 2005
#36
  • Aug 11, 2005
  • #36
They were equal length (1 5/8 tubes) Chrome BBK shortie. They both went in from the top. The drives side was a real PITA
94MustangGT5.0
288
Champaign, Illinois
Aug 11, 2005
#37
  • Aug 11, 2005
  • #37
Yeah, are cars definitely have headers, despite how poor of an effort they are, they are not a manifold (cast iron typically). I thought the new '05s have a combination of the two, were they are individual tubes, yet formed like a cast manifold.
Scott_95GT
387
Sacramento
Aug 11, 2005
#38
  • Aug 11, 2005
  • #38
-Headers look great under the hood.
-Take a matter of a couple hours to install.
-Can easily be purchased used, as long as the are 1-flange style.
-Can be installed with simple tools you probably already have, and is a good starter project to build confidence on working on your car.
-Will add a couple easy rwhp on a stock motor, a bit more on a modded car.
-No mater what you do to your car, you can still use headers. The needs for other mods such as Intakes, maf's, inj.'s, chips, TB's, can change depending on application (More cubes, power adder, ect.)
IMO the headers are not a bad chioce. Obviously they won't put you in your seat, but they are an all-around nice upgrade.
94GTLaserRC
11,178
Aug 11, 2005
#39
  • Aug 11, 2005
  • #39
And dont forget the sound
V8302stangs
211
San Jose, CA
Aug 16, 2005
#40
  • Aug 16, 2005
  • #40
I decided to stick with the shorty equal lengths. I got them on the car on my own with pretty much average garage tools. It sure was a lot of working and scraping, but otherwise wasn't bad. All I have left now is to put all the externals back on (intake, plug wires, bolt the passenger engine mount, dipstick etc.)
  • 3
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
