I pulled my codes!!!
  • Thread starter Thread starter FriscoSteve
  • Start date Start date Apr 27, 2010
F
FriscoSteve
36
  • Apr 27, 2010
Ok folks - if you followed my other thread labeled, "HELP PLEASE, NO POWER", well I finally was able to get my codes. Pretty cool I must say!
Reminder, this is a '93 GT 5.0 EFI in my 1966 Mustang with AOD.
KOEO Codes are:
15
26
85
84
I believe 84 is EGR vacuum solenoid circuit failure, but I don't have any EGR, so I think this is just a false code.
How about the others?
L
Lawbreaker5.0
543
Texas
Apr 27, 2010
  • Apr 27, 2010
15 readout memory test failed
26 MAF was out of range (this is the problem more than likely)
85 canp circuit failure
84 egr vacuum failure
L
Lawbreaker5.0
543
Texas
Apr 27, 2010
  • Apr 27, 2010
You did the test with the engine hot right?
F
FriscoSteve
36
  • Apr 27, 2010
Engine was warm.
L
Lawbreaker5.0
543
Texas
Apr 27, 2010
  • Apr 27, 2010
I would clean the maf with a electrical cleaner. They make stuff specifically for MAF's. Disconnect the battery, leave it off for a few min, pump the brakes then hook it back up. Drive it around for a while and check the codes again. If the 26 code is still there, try to get another MAF from a working 5.0 and place it in there. I wouldn't buy a new one just yet, not until I knew for sure that the maf was the culprit.
F
FriscoSteve
36
  • Apr 27, 2010
I already tried cleaning it with MAF cleaner. Nothing. I couldn't find one to borrow, so I ordered a new one, just waiting for it to get here.
I ran a test on all four wires on the oval plug going to the MAF sensor and all check out as they should.
Should I run a KOER test?
L
Lawbreaker5.0
543
Texas
Apr 27, 2010
  • Apr 27, 2010
Yes. Have you disconnected the battery yet?
F
FriscoSteve
36
  • Apr 27, 2010
No, not since before running KOEO. I'll run KOER tonight and post up.
F
FriscoSteve
36
  • Apr 27, 2010
Ok, I ran the KOER test. All I got was Code 33, which is EGR related, and I don't have EGR, so no real codes pulled at all.
So what do we do from here? Again, this all goes back to the larger thread 'Help Please, No Power'.
Any ideas???
MustangLX-5.0
856
Lehigh Acres Fla.
May 2, 2010
#10
  • May 2, 2010
  • #10
You said the MAF test results were within range or good. What tests did you perform? Did you check Pins D & C for proper resistance range while key off? If so, what values did you get? Voltage between C & D with KOER, what voltage did you get?
Anyone know what the dea with code 15 is?
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Ran my code reader and
  • Mindseye007
  • Aug 10, 2024
Fox 5.0 Mustang Tech Aug 19, 2024
Mindseye007
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
