I think I jacked up my thermostat
kiddiccarus
The first widely accepted Tranny
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
OK here it is start to finish.
I replaced the thermostat last spring to see if that would fix my heater. Didnt work.
  1. Replaced the the thermostat to see if it would fix the heat issues : Did not work
  2. Replaced the heater core: Did not work
  3. Checked all of the wires hoses and anything I could think of that may be the problem: No heat still
Well I remember when I replaced the thermostat I was going off the Haynes repair manual (I kick myself for ever buying that) and it told me that I needed to ensure that the thermostat was in the open position. Well I did that and I pulled on it some to make the slider go to the open position. My questions are on a NEW thermostat, Did I have to do that? Did I pull it too far? Did I break it? Did I jack it up?
I think you jacked it up. when you put in a new thermostat, you don't have to mess with it. I think what the manual was trying to tell you that the "open position" means that when you place the thermo in postion you will be able to see that it indeed open. when properly placed you will see the the thermocouple.
Agreed. but I dont see how you destroyed it. those springs are really stiff. LOL but if you used any tools to try and "open" it then you proly did do some damage.
also make sure your pump is doing its job.
have fun.
TF
mr_woodster said:
my heater made good heat even with no t-stat :shrug: sure its not something to do with the heat controls?
I hope it is not, I have tried everything but the actual replacement of the controls. I am scared of the price of them. I need to goto the J/Y soon and see what I can find.
Well the new stat is in, the old one looks functional but I dont trust it and at 4 dollars I think the new one will be fine.
I see temperature for the first time on the guage in a year. I will see how it heats when I go to work tonight
BTW did I mention the huge freaking screaching under the hood now?????? Seems that the A/C pump is not rolling like it should with the belt. The a/c works fine though. I turn the heater/ac control off and it stops then turn it back on and well screaching again.
Not ssure exactly where it is coming from but it is in the Heat/ac portion.
If it is the A/C clutch dying, simply unplug the electrical connection at the compressor. When you use the "mix" portion of the heater control it runs the A/C compressor so as to keep it in good running order in the winter. I did this on my 89 untill I fixed it. It has been unplugged on my vert for almost 2 years. Un-hooking this will not affect the heater operation
