Actually, there's one sure-fire, 100%, no exceptions way to tell - that's via the plant code & unit # from the VIN.
The 2nd digit is the plant code - F=Dearborn, R=San Jose, T= Metuchen. The last 6 digits are the consecutive unit number.
For Dearborn cars, anything less than 250000 is a "64-1/2", anything 250000 or greater is a 65.
For San Jose cars, anything less than 125000 is a "64-1/2", anything 125000 or greater is a 65.
ALL Metuchen cars are 65's - No 64-1/2's!
This method is sure-fire. Vin's can't (legally) change. I've seen radiator supports change (commonly wrecked or rusted). People upgraded from generator to alternator. The engine code mentioned above is accurate - except K-codes were used for both groups... Then, you have all the running changes - center-off heater, lock knobs, carpet, door cranks, spare tire holddown, etc. My 65 is a November San Jose car, and has many of the items commonly considered "64-1/2", but it's NOT!
The vin method listed above is 100% accurate, since Ford "skipped" about 20,000 numbers at each plant when they changed over.
