i think my t-5 is on the way out.....
PeteyAce
346
i usally have no problems with it besides annoying gear whining. but when i put the car in reverse it made a very unhealthy noise, only when i put it inverse, and i know its the the gears in the rear, i know the diff between them and the noise is defintely coming from the trans. if it is on thw way out should i rebuild it or just get a new transmission?
I_AM_CANADIAN said:
Does it grind going into reverse? If so thats normal. Reverse doesn't have a synchro, so wait a sec before you engage the gear.
That`s true,but theres a trick.When you want reverse,shift into first then go to reverse.
It gets rid of that grinding sound.:shrug:,try it and you`ll see what I mean.
