I think the alignment guy is trying to screw me
  • Thread starter Thread starter DJCarbine
  • Start date Start date Jul 2, 2007
D
DJCarbine
392
  • Jul 2, 2007
Did the shelby drop, and as much as I hate letting others work on my car, I had to get it aligned. Dropped it off at a place with the specs, they said they are familiar with older cars and that they would take care of me.
2 hours later, the guy says he cant align the camber, because the bolt holes where I dropped the control arms are supposed to be elongated to let the upper control arm be adjusted
I have no idea what hes going to charge me cause I'm posting this from my cellphone, isnt the camber adjusted with SHIMS, not physically tweaking the control arm
Has anyone else had issues with getting their cars aligned after the shelby drop?
Personally, and excuse my french, I think he is full of ****.
D
DJCarbine
392
  • Jul 2, 2007
It appears that the holes I drilled have been elongated the tiniest bit. I admit I was a cockhair off on the drilling, so I just took the bit and made the hole slightly bigger tword the drivers side, no more than 1/32nd of an inch. This allowed the control arm to slide in, but allowed for ZERO movement in either up/down left/right.
He should have still been able to adjust the camber am I not correct?
G
gjz30075
250
Roswell, Ga
Jul 2, 2007
  • Jul 2, 2007
Totally agree. The camber and caster are adjusted with the shims, Shelby drop or not. As a rule of thumb, you can remove half the shims on each point after the drop.
CraigMBA
783
Orange, CA
Jul 2, 2007
  • Jul 2, 2007
I don't think he's trying to screw you. I don't think he has any idea what he's doing.
Buy some gauges and learn to do it yourself.
D
DJCarbine
392
  • Jul 2, 2007
I just jacked the car up and made a rudimentary camber kit out of a peice of aluminum and a protractor. I took the UCA bolts off and with a tap of my trusty hammer I was able to adjust the UCA as to add/subtract shims.
He was completely full of ****, if my skinny ass can do it anyone can
I'm setting the alignment myself, he said that he adjusted the toe in but couldnt do caster/camber. Camber was @ -.5 degree on one wheel, and -.4 on the other. Close enough for now.
D
DJCarbine
392
  • Jul 2, 2007
Oh, and the reason I went to the shop was because the guy said he just did a 65 mustang alignment, and a mach 1 but didnt know what year. I figured heck, he must know how to do SOMETHING......
stangman67
294
connecticut
Jul 2, 2007
  • Jul 2, 2007
The lca is also adjustable with an eccentric.
fasttback
471
Northern CA
Jul 2, 2007
  • Jul 2, 2007
Pre 1967 cars did not have an eccentric - I wish they did. Shims on the UCA were the way to adjust it. You can buy an aftermarket one and weld it in though.
coolblue65
1,224
Algonquin, IL
Jul 2, 2007
  • Jul 2, 2007
There is a shop in Bennsenville accross the street from the Mustangs of Chicago store that does all of there alignments, I have not personally taken in there, but I know they know what they are doing on old mustangs.
stangman67
294
connecticut
Jul 2, 2007
#10
  • Jul 2, 2007
  • #10
thats good to know about the earlier cars, thanks.
I
iapexl8r
254
Jul 3, 2007
#11
  • Jul 3, 2007
  • #11
mustangs plus sells a kit to adjust the lca with a eccentric I did my 65 and would recomend it. chris
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
New to me 98 Cobra
  • bird_dog0347
  • Feb 25, 2025
2K
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
FastDriver
