I suspect that Michael Flatley has left the river dance, and works inside my Mustang now.
Why do I hear a tapping sound: I hear it when I am accelerating. There is no tapping when I idle, or when I maintain speed. It only does it under strain. If I am in Neutral nd I rev the engine, I do not hear any tapping. It's only when driving.
I have ruled out a Manifold leak by putting a bit of transmission fluid in the carb and verifying that smoke only came out of the exhaust rather than in the engine compartment.(this was advice I got from the Motor Men on a local radio station)
So, how do I determine the cause of the tapping, and how to I resolve whatever the potential issue might be? For example, someone told me it might be a dead lifter. If that is the case, how do I confirm it and how tdo I fix it.
someone told me to put in some wizard mystery oil something or other. that seems to have had no effect.
This just started yesterday by the way.
I was about to unload on you. ( it can't be the plugs, cause they're too hard to remove?)
Then Krash tells you to rotate the distributor a COUPLE degrees , not a few hundred, then you also decide that's not it.
