Got a new dream, no longer want to put a mod motor in a stang, it's been done, and I've found a better solution. Al Dart 302 block. Very light and strong.
So I'm aiming for about 500 or close to fwhp, for use in a street-car with power brakes.
Combo: forged 331 stroker (10.5:1 on 98 octane), roller cam, chrome-moly steel roller-rockers, AFR 185 hi-rev heads, 4-into-1 extractors (2.5" dual, X-piped exhaust with staggered flowmaster 40 series)
Induction will be way of fuel-injected individual-runner manifold. Will most likely be getting air from cowl.
Accessories: air-con, ps, a 200A alt, march Al performance pulleys, no fan (will have electric)
I was thinking about using an MSD Coil-Per-Cylinder distributorless ignition.
Parts that will get a low friction coating (if possible, haven't researched fully yet) are: rod pins, piston skirts, cam lobes and bearings, valve stems.
Parts that will have thermal barrier coating are: valve heads, piston crowns, exhaust headers.
Pistons would be vertically gas-ported to use lesser-tension rings.
I was thinking that coupling the fuel-injected individual runner to a fairly agressive roller cam would still give good idle and response qualities, but still give very good power. Add onto that the friction combatants: coatings and rollers, you use less power running the motor, more for the flywheel. Lastly it will have a highish rev limit with the forged, and rollered components, probably set to 7100rpm to 7500.
So who thinks the power goal sounds do-able with that? I think the FI-ind. runner setup will make it possible, give better response from a more agressive cam, and still give big lungs at high rpm.
EDIT: The block would be CNC blue-printed, and parts matched and balance.
well, if I'm going to do it, it's going to be done properly, and I'll always be going "If I had have just waited another few months, I could have got it perfect." if I don't do it right first time. I'm a hard customer to satisfy. It sucks being so picky, but I won't be happy if I settle, so what am I to do? lol
