I thought the track was supposed to hook harder than the street!
StangLou said:
Was at Darlington NC for the Test and Tune night for Mustang Week. Decided to pay my $10 and make a few passes. On the street I have 0 trouble hooking. The tires will make a couple quick rotations, then bite and Im off. First time I lined up I hazed the Nittos to a light smoke, staged at 2500rpms, and waited for the lights. Tree fell and I side stepped the clutch and spun all the way through 1st and all the way through 2nd :notnice:. It bit in 3rd and I was off. Passed the line in 14.9 seconds with a 2.8 60ft at 98mph!!! I was ticked to say the least. Figured my Nitto's would hook better than that.
Lined up the 2nd time. Light smoking of the tires, staged at 2000rpms this time and dumped the clutch. Again I went to spinning completely through 1st, and most of 2nd. It bit over halfway in 2nd, I missed 3rd and said screw this run. 17.6 with a 2.4 60ft at 59mph lol.
Final run I was determined not to spin. Hazed the tires, and lined up. No staging this time. I waited for the light and took off like I normally would from a stop light. Once I got rolling I stomped the gas and of course spun like mad :bang:. Spun all the way through 1st, but caught 2nd this time. Nailed 3rd perfectly and passed the guy I was racing, powershifted to 4th but I was already at the finish line by then. 60ft was 2.3 :bang: 1/4 was 14.6 at 96mph.
Somehow my time and mph went down :shrug: I powershifted every gear except from 1st-2nd. I also drove around the water box each time. Anyone have any advice for next time Im at the track. I know Ill get better with practice, but I expected MUCH better hooking racing at the track than on the street. It was humid as crap that night, and finally rained on us before I could do a 4th run. Best time I saw all night was a nice clean green notch... 8.9 seconds at 149mph!!! Best time I saw from a modded Cobra was a 12.4. Best run I saw from a Mach I was a 13.6. Most Mach's and modded GTs I saw race were in the 14's so I didnt feel to alone. Ehh live and learn I guess.
i race at new england dragway on street nights ( no track prep, they just clean it) and i got ok times out of my car.. you don't need sticky compund of 13 second cars like ours you just need practice.
1. drive around water box and do a lite burnout too clean the tires off
2. if your a manual bring the rpms to around 3500 rpm's and let the clutch out quick but not dumping it. you want it too slip a little and you should be fully off the clutch after a few feet out fo the hole. you should only go a little harder on the gas then it took too bring the rpms up too 3500 at the line. as you get a few feet out then quickly but not mashing it go too full throttle.
3. POWERSHIFT!!! you need too get too the point that your shifting fast enough that you can shift without lifting at wot and not hear the engine rpm surge up before the next gear engages.
this got me 13.90's with just flows and a K+N drop in for mods i have a clutch and quadrant too but that is not goign too do much.
Track prep = called track bite.......
They spray the surface with VHT or somthing like that.
VHT TRACKBITE SP-162 is an exclusive consumer formulation designed to offer controlled traction for competition drag racing. VHT TrackBite is a liquid track treatment, which improves traction by means of adhesion and does not soften tires nor the track surface as other imitation products may. SP-162 is packaged in a one gallon bottle.
I use a FM radio at the track to talk to my driver friends.
When I see them spray the track, I tell the driver !
Result:
12.8 @ 110 in a BONE stock Cobra
No tire spin.........
Result:
they don't spray the track on street nights at NED :( i bet they don't because of parts breakage delays. the goal on street nights is too run as many cars as possible.
i have in one case saw them spray one of the lanes down for a guy that was running in the 8's :D i wish i could have run right after him but my car was parked at that time and i was watching some racing.
track prep means nothing when your running a street tire. the VHT they put down actually has an adverse effect on a normal street tire. smoking your street tires to heat them is also a bad idea. the oils from the tires actually seep out once the tire has been smoked and make it more slippery.
the best way to a decent 60ft on a stock tire is to just go around the waterbox, do a first gear clean off burnout while pulling forward, and then stage and launch slipping the clutch in the 2500rpm range.
RageStangX said:
heh, go to atco the worse track ive ever been too, no track prep and they never know wtf is going...there is no order to anything.They need to dig there heads out of there azzes :mad:
your kidding right? this can't be the same atco i used too go too back in my turbo regal days. that used too be the place you went too run your fastest times. plus it was open year round.
I went to atco a few weeks ago with my neighboor's small block rx-7 (yes i said smallblock! lol) and he coudnt get it to hook at all. at englishtown he runs 7.80s to 7.95s at atco his best run was 8.47. Still not worse than the old westhampton track on long island...that place was just a ****ty strip of straight road...never any prep. you didnt go there for good times... just to have some fun racing.
