I wanna Buy Some HIDs...but
I was gonna do HID's. The thing is to me it doesn't look good to have HID headlights and halogen foglights. I would need to do both sets and at $400 each it's n ot gonna be cheap.
SO instead of $800 for a full HID front end, i just spent $50 for Silverstar headlights and some ricer fog light bulb that was white (cuz silverstar fogs burn out after a month)
Sylvania corrected their manufacturing process, the fogs no longer burn out so quickly. Also, it is important to wear gloves when installing these. The oils on your fingers will lead to premature failure.
Henceforward said:
All you need is 4100K, Osram Sylvania makes them, and all the BMW, Mercedes flagship cars have 4100K
Anything higher is rice. You don't need blue, or purple lights...
http://www.intellexual.net/hid.html
"There are many companies and private merchants out there that will advertise 7000K, 8000K, and even 12000K HID kits. Most of these vendors lurk around on ebay, online car forums, websites, and ricer accessory shops. 100% of the people that buy these kits do so because they are uninformed, uneducated, or misguided in the field of lighting, and will buy these junk kits thinking three things: that these bulbs are brighter, that these bulbs should cost more money, and/or that they will perform better. All three statements are completely false. Perhaps this misconception and frenzy for purple lights originates from BMW and Audi's infamous Hella projector HIDs.
So allow me to explain the real truth of the matter... Philips is the number one manufacturer of HID bulbs. The Philips OEM D2S bulb is rated at 4100K at 12.8 volts and produces 3200 lumens of light. The Philips Ultinon D2S is 5800K at 12.8 volts and produces 2400 lumens of light. As you can see, with all other factors remaining constant, the brightness of an HID bulb declines the higher up the color index you go. Vision, a Korean bulb manufacturer, makes an 8000K bulb, which they used to advertise on Acura-Forums as 2000 lumens bright. This is barely a marked improvement over halogens, and will produce more glare and eye fatigue than it is beneficial. 4100K has been proven through tireless independent research by the Germans, Japanese, and Americans to be the most functional, truest white and thus the brightest possible color temperature (ceteris paribus).
Every car manufacturer in the world (including BMW and Audi) uses none other than a standard 4100K gas-discharge bulb. No exceptions. The reason being is that 4100K is daylight white in color and produces the same color visible light as direct sunlight. This is least fatiguing functional color on the eyes and produces the most comfortable contrast on the road."
Notice the glare, ebay kits really do suck.
Proper HID kit with no glare, very crisp sharp lines. 4100K. :nice:
you must of had a crappy kit, first off their is many things to consider. First off Mercedes uses 4300k Philips in their caps, 4200k Osram in their lower-end vehicles. 6000k Philips in their SL's and CLS models. BMW *only* uses 5800k in their 7 and 5 series and 4300 in everything else. My brother works at Mercedes of Palm Beach and this is the case on my dads clk 55 and s430 also. HID's are *never* going to work proper on a mustang or any type of car that doesnt have a functional projector that projects the HID beams toward the road depending on the angle and heigh of the road, every street is different and *real* Hid's adjust to the road surface. with that said, the best HID kit you can have is a OEM one. The OEM ballasts are really some of the only non-crap ballasts you can purchase. My brother gave me some wrecked Bosch ballast out of a e500 and I ghetto rigged up some philips d2s bulbs 4300k out of the e500 and siliconed them to our stock headlight housing. Didnt project light or color like I wanted and recently got some 9007 HID bulbs in 8000k. thats right, the 9007 bulbs fit *SNUG* and Perfect into the housing and snap in with the stock black circular piece that we use to keep our halogen bulbs in. They fit just like stock and the aim is amazing compared to my silicone ghetto setup. The 8000k is beautiful and looks 10x better then my dads clk55 or my friends g35. My sister has a 350z with hids and she envy's my lights. I will post a pic once I find where my data cable for my digital camera is. Here is the link to the seller that sells the STOCK FIT hid bulbs on ebay.
http://cgi.ebay.com/ebaymotors/HID-...36476QQitemZ7997804410QQrdZ1QQsspagenameZWDVW
The lighting on my car at night is so beautiful, it makes the car look like a million bucks, the quality on the bulbs are amazing and the guy has 100% feedback. Now let me remind you that the higher Kelvin temperature the less light you actually have to light up the road. The more color, The less light and brightness. But IMO you barely can even tell. 4300 is a big difference from 8000 but 6000 and 8000 is like not a big difference, go with the 8000 has it sets you apart from *every* car on the road.
btw 4300 looks like ass, 6000k and 8000k look much nicer. Nissan Maxima/ Audi / BMW all have 6000k and it is beauttttifuuul.
Just one more thing.
An HID retrofit is not legal. This may be an issue to some come inspection time or out on the road with cops.
The only Legal retrofits are if the vehicle was available with HID"s and you used factory parts. An example is a Focus going HID using SVT focus headlights or a 1st gen Mark 8 going HID using parts from a '96 LSC.
Same deal with a benz or audi or BMW. You can upgrade to HID as long as that model did have it available and you use the factory parts.
Since the only Mustang to come with HID's is the 2005 Saleen, that means any retrofit to a 64-04 Mustang is technically illegal. This is due to incorrect headlight housing and the lack of a fuctional high beam when using an HID retrofit.
Ok i am think i am gonna go with the 6000 or the 5300...what does everyone think. Both From ultrabrightlights.com. Tell me what you guys think.
Give me Thumbs Up or Thumbs Down
Give Me TP said:
8000K headlights and fogs, and I couldn't care less whether the typical fool who has never used them and can't afford them thinks it's rice.
No need to resort to name calling just because someone does not agree with you :notnice:
Especially in tech :notnice:
No specific user names were mentioned so it's appropriate in my opinion. Rice is a term used frequently by those who are ignorant of the functionality of what they consider an "appearance-only" mod that they haven't ever used themselves.
Digital cameras s**k at taking front-on headlight pictures, or maybe it's the user (me). The 8000K headlights are actually much better in real life than as shown, while the fog lights are pretty close in real life to those in the pics.
