I wanna Buy Some HIDs...but
SRT Handz said:
Ok i am think i am gonna go with the 6000 or the 5300...what does everyone think. Both From ultrabrightlights.com. Tell me what you guys think.
Give me Thumbs Up or Thumbs Down
Thumbs up on www.ultrabrightlights.com
I bought a 8000K McCulloch kit for my wife's 2004 Mustang from their eBay store (seller name: ultrabrightlightz) and it is of excellent quality. Make sure you get wiring harnesses that use relays in whatever kit you buy or seller you buy from.
how bright can you go with HIDs before they become illegal..as far as brightness goes...im thinking about getting a kit...cuz i am paranoid of the deer by where i live...i cant see for **** with my stock lights
Henceforward said:
All you need is 4100K, Osram Sylvania makes them, and all the BMW, Mercedes flagship cars have 4100K
Anything higher is rice. You don't need blue, or purple lights...
http://www.intellexual.net/hid.html
"There are many companies and private merchants out there that will advertise 7000K, 8000K, and even 12000K HID kits. Most of these vendors lurk around on ebay, online car forums, websites, and ricer accessory shops. 100% of the people that buy these kits do so because they are uninformed, uneducated, or misguided in the field of lighting, and will buy these junk kits thinking three things: that these bulbs are brighter, that these bulbs should cost more money, and/or that they will perform better. All three statements are completely false. Perhaps this misconception and frenzy for purple lights originates from BMW and Audi's infamous Hella projector HIDs.
So allow me to explain the real truth of the matter... Philips is the number one manufacturer of HID bulbs. The Philips OEM D2S bulb is rated at 4100K at 12.8 volts and produces 3200 lumens of light. The Philips Ultinon D2S is 5800K at 12.8 volts and produces 2400 lumens of light. As you can see, with all other factors remaining constant, the brightness of an HID bulb declines the higher up the color index you go. Vision, a Korean bulb manufacturer, makes an 8000K bulb, which they used to advertise on Acura-Forums as 2000 lumens bright. This is barely a marked improvement over halogens, and will produce more glare and eye fatigue than it is beneficial. 4100K has been proven through tireless independent research by the Germans, Japanese, and Americans to be the most functional, truest white and thus the brightest possible color temperature (ceteris paribus).
Every car manufacturer in the world (including BMW and Audi) uses none other than a standard 4100K gas-discharge bulb. No exceptions. The reason being is that 4100K is daylight white in color and produces the same color visible light as direct sunlight. This is least fatiguing functional color on the eyes and produces the most comfortable contrast on the road."
Notice the glare, ebay kits really do suck.
Proper HID kit with no glare, very crisp sharp lines. 4100K. :nice:
You seem to have researched this issue thoroughly :nice: are there any kits you would recommend including fogs. Links would be appreciated.
Thanks DEW
this thread has made me research this topic a little bit...i went to ultrabrightlights.com and found a few pictures that make me warry
the luminosity is great...however it doesnt go very far out and just covers whats directly in front of you...i thought hids were supposed to fill the viewing area with light...or would this require projection headlights? im not liking how short of a distance it goes...or is the picture a bad example?
nighhawk..well those look like 8000k to me..IMO they *look the best but they dont emit the Most light..thats because they are 8000k..thats how mine look..but let me tell you something..they are about 26 times better then stock in distance and viewing..On a dark road you can see *everything*..that picture doesnt mimic what you will be seeing in real life..regular halogens light up like 1 foot..*properly*
all i have is my digital camera right now..i will give u good pics tommorow..but here are some BS pics from my garage..(too late to start up the car and drive..people are sleeping:) with my motorola razor phone
my hid's crush my dad's s500 and his clk55..no comparison..will do COMPARE pics tommorow WITH A REAL DIGI CAMERA..not my cellphone. I left it at work:(
Note that you can adjust your headlights vertically, but I have not found that to be necessary with the two cars on which I have installed HIDs.
Not meaning to preach, but again make sure the wiring harness in whatever kit you may buy, whether from www.ultrabrightlights.com or elsewhere, uses relays. These are being omitted from some cheap kits lately, and it's worth the extra $$ in my opinion to buy at least a good quality kit. It also doesn't hurt for you to add a diode into the kit wiring harness, your stock headlight wiring circuit may thank you.
thanks you two..when i go home for the year from college im probably gunna buy a kit..i remember when they were like a grand for a kit lol
HID's in projectors
Is it true that if you do buy projectors for 99+ Stangs, that HID's will not fit in the projector housing? I have heard this many times from friends and people online. If this is so, why can't you put HID's in the projectors? :shrug:
The 9007 bulbs that fit the stock headlights are not the same as those that fit projectors, and there are issues with high beams.
What do you mean add a diode to the kit wiring harness?? It's easier to ask and understand from someone other then an instruction manual.
It's not in the instruction manuals that come with these conversion kits. There will be a connector in the kit harness that plugs directly into your headlight wiring harness connector. I soldered a diode into the kit wiring just after this connector on the positive side to prevent any discharge from the HID ballast from running back through the stock wiring and headlight switch when the lights are turned off. Insurance against gradual erosion of the headight switch contacts and wiring. Additional protection is offered by using relays in the kit harness, for another reason. By the way the stock wiring is left completely untouched and unspliced by these kits, which is a very good feature.
