I want to put on 305/35/18 tires on the rear, but which size up front?
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
I saw some nice drag radials on want to put on the rear (305/35/18), but any suggestions of what to put up front? I want something that wouldn't disrupt my ABS and something that is known to go together with them.
275/35/18 is too wide. they will follow every imperfection in the road. trust me i work at a tire shop. get the 265/35/18 and they will work fine. you will not have a problem with the 295/40/18 either. my buddy ran them on his cobra for years with no problems
Will 275/35's be okay for the front with my car being lowered by the pro-kit? I rub my eibach sway bar on harsh turns with 255/35 currently.
oh and what's an OD?
265s are always fine, i've heard of 275s rubbing. I've never heard of problems with 255s before though? Where did you buy your rims? Maybe the offset is wrong? 265s might track slightly less as others have mentioned.
OD = outer diameter. You want the diameter of your tire to be close to stock. Too much extra sidewall (i.e. those 40 series 18s someone mentioned) and youll run into rubbing problems. For the rears this will affect your speedo also.
The ones in bold in the spreadsheet I posted are closest to stock tire OD.
