Green94GTvert said:
I'm ASE certified and experienced when it comes to fords.
Adam
Green94GTvert said:
I will pull the codes as soon as I can guys. Adam
I don't want to be rude, but you should know that step one with these cars is pulling the codes. There are far too many possible issues to try and diagnose these cars "old school."
Again, I am not trying to be rude.
The problem is that most often codes are that last diagnostic step people undertake.
Diagnostic codes should be the first thing you do.
Clocking the MAF usually works when there is a tight bend in the intake tube just before the MAF (as with fender mounted CAI kits), or a conical air filter is attached directly to the MAF.
There are other fixes, which may work better, but will be more of a hassle to install.
You did not mention the air filter/maf setup; I am curious?
I think you have other issues, even if clocking the MAF does help a little.
What is your TPS set at?
Is the voltage output of the TPS consistent when you work the throttle?
What are the trouble codes?
I could give a rats @$$ about the $10. Just trying to help.
jason
