IAC modifications?
carbed 85 gt
121
Honolulu HI
Hey I just fot the trickflow kit and the car surges with the IAC connected but when warm without the IAC connected its a solid 800 rpm. I have cleaned the IAC but someone told me there was a plate you could buy to let more air around the IAC or you could dremel the passaeges for tihe IAC larger. Are there any truths to tthese rumors?
Yes, one can use a bypass plate. I think Jrichker even provided a link to it in his Idle Surge Sticky.
I am not sure why you want it - is 800 RPM not high enough or are you wanting to do away with the IAC altogether?
Good luck.
Good luck.
HISSIN: It idles at 800 rpm WITHOUT the IAC connected when warm.
The idle air bypass plate may or may not solve your problem. My GT would surge and die at stop lights or when I'd turn a sharp corner and the plate seemed to stop that for me, but it doesn't work for everyone. You can get it at your local ford dealer, although I had to provide the part number because my local dealers had no idea what I was talking about. It was around $35. I thought I had the part number, but I can't find it. I know I've posted it before though.
Here's a link to the part at www.50resto.com http://secure.50resto.com/product1.cfm?SID=1&Product_ID=2123
After my 347 install my car would idle cold but after it warmed up it would not idle at all. While driving, push the clutch in and it died. I bought the IAC adjuster plate from my Ford dealer. It was $37. Problem solved. It has a new Ford number. F2PZ-9F939-A
