IAC valve didn.t helped. Help!!!
After reading a month ago or so about other Mustang owners having the idle problem and supposedly fixing it changing the IAC valve I made the same thing and replaced the valve. For my surprise the problem wasn't solved and I already spended a couple hundreds trying to fix this problem.
Any suggestions on how to fix this problem.
The car starts rumbling mopst of times when you make sudden brake and the car stops.
And also frequently when you are halted like on a red light.
I will appreciate any help
Thanks
Heriberto Lopez O.
Thanks
Heriberto Lopez O.
Is your check engine light on? Did you get codes pulled? I'd check all the usual things like fuel filter, plugs, wires (if applicable), air filter, vacuum leaks, battery (old one might not hold much charge).
I would start there a loose spark plug or brittle wire can screw everything up. In addition you could alsway check your TPS (Throttle Position Sensor)
Can't you have the shop diagnose the problem? I'd hate to see you keep trying things and costing you $ and not solving the problem.
Do you have a K&N air filter? Did you clean it recently? For a last shot here, list all the info about your car and any mods made. See my sig for example.
thanks
i'll have the guy at the shop check the info from the computer. I didn't do it yet since when I took it out from the shop the check engine was off. Until today the check engine appeared again.
My stang is completely stock.
I have done some repairs on it:
Alternator (repaired)
Radiator (new)
Rear axle shaft (new)
I'll appreciate any help you can provide me, since it's very frustating to spend money on it and the problem still being there.
Today after parking the car and instantly trying to restart it to park it elsewhere, the car didn't started, and after 20 minutes aprox. I tried it again and the car started normally as if nothing happened. Is the second time that does this, the first was about 2 months ago.
Do you have an email address where I can contact you more often?
Best Regards
Heriberto
MexStanger said:
the mechanic bought it from a parts store.
Thanks
thers your first problem, Never by Electronics for Fords from parts stores. always go-to the dealer for these parts. the factory stuff might be more $$ but there designed to work on your model, make and year car/truck, where the aftermarket makes a part work for a much broader range of vehicles.
Top this: Monday went outside to start the Mach. Starts up, then dies. Start it again.. starts and dies. Start a 3rd time & hold the gas down.. stays alive only if given gas. In this condition, I was able to back the car out, and drive to the rear of my work parking lot (the car stalls between shifts since I don't have a third foot to hold the gas down a bit :mad:) By the time I drive the car in 1st gear to the back of the parking lot, it's now idling fine. WTF. I immediately drove the car to Ford and dumped it. They can't duplicate the problem, and think it was a stuck IAC or something. OK... it's getting fixed for 2nd gear grind and a few other things, but looks like I'm SOL on the stalling for the moment. Emailed the service mgr this morning demanding a second look, but we'll see. :notnice:
What you describe is 99% likely to be stuck IAC valve... It is intermittent. Make them f'n replace it under warranty...
I agree the IAC seems to be responsible, but since they can't duplicate it they haven't offered to replace anything in regards to that. Any recommendations on how to demand a new IAC? Sux.. I hear the Mach's IAC in within the manifold, so it's not as simple as me buying a $40 part and removing two bolts like the Gt.
The IAC is a VERY tempermental part that has plagued these cars for some time. It's no doubt they will have a tough time duplicating it. It's almost as if the car senses it's guts are going to be poked and it acts fine while getting serviced/repaired. :rolleyes:
Yeah.. sux. :notnice: I just left a message on the svc mgr's cell that I want the IAC looked at again, but I'm sure it'll check out ok. :(
depending on the build date, it could also be a problem wth the FPR sensor as there was a design change effective 12/6/02 the old problematic ones have a stamp # of f8cf-pf972-bh and were replaced by the new (improved) designed part # 3R3Z-9F972-AA
Build date for me was 11/22/02, so I have the crapper part. :nice: Forgive me.. what does FPR sensor, and can is it easily replaced? I have a feeling I'll be nickel and diming some parts myself.
FPR = Fuel Pressure Rail sensor, its a little square black sensor bolted down on the fuel rail, we sell the hell outta' them. price is @$50.00
Is the part easily accessible without removing much? I'll replace it myself if I'm unsuccessful in getting Ford to do more work.
*It's not my intention to hijack your thread MexStanger - hopefully this info is of value to you as well. :)
yeah, I dont think it's to bad. might have to re-move the shaker asbly but that should be all
