idle issue
myslo50
247
ohio
i need to know how to adjust my idle, i just wired in my mass air and now it idles wao too low. way lower than when i was sd.
also is 24# injectors a little to big for a stock 5.0 with a explorer intake, headers, exhaust. i have a pro-m mass air meter matched for the injectors.
last, what is a hot plug i can run?
Yes 24's are way too big for that application. I would say get the Pro-m calibrated to 19's and throw the stockers back on there. How did you set the idle speed. Go through that checklist above...its very helpful.
i didnt adjust the idle speed at all. i just wired the mass air in and it idle really low to the point where it idles like it has a small cam in it. cause it stalls when im down shifting up to a light.
ill check the surging idle checklist im still trying to figure out where all the stuff is on this website
seeing how i got the pro-m mass meter i dont know if it is a 70 or a 75mm meter,could i use the stock 19# meter out of a stock 89-93 mustang on the pro-m. i have a spare meter i could put on with the 19# injectors for now, until i get more motor for the 24#ers.
or would i have to get a pro-m 19# meter.
