- Oct 6, 2006
- 26
- 0
- 0
First of the car has a systemax upper, 70mm TB, edelbrock TB adapter, 70mm Mass air, exhaust and some other stuff. car starts up fine and is drivable.
ok i am still having problems with my idle, it idles at 2000 rpm except when you first start it, it idles at 1500 rpms (clutch in or out). I took the upper off and replaced all gaskets (TB, EGR, IAC, etc..). I found no vacum leaks. However the pcv valve was completely open, basically there was a hose coming out of the pcv valve and there was a T fitting at the end of it. Both sides of the T fitting were open. So i capped off both sides, didnt help. The idle screw is backed out all the way or else it would idle higher. I cleaned everything with carb/TB cleaner (TB, IAC, etc..), didnt help. I tried resetting base idle, did not work. We now think it could be that the timing is way off.
Any ideas of what else could be wrong? Any hoses that commonly become disconnected that i could have missed? Should i replace the Idle motor thing? What should the PCV be connected to?
I haven checked the codes yet but i will this weekend....
any thoughts would be great, i have been slacking but now i really need to fix this..
thanks
jeremy
thanks
jeremy
