  • 2.3L (N/A & Turbo) Tech
Idle issues
  • Thread starter Thread starter tim_lemmy
  • Start date Start date Jan 31, 2008
T
tim_lemmy
94
  • Jan 31, 2008
My 93 LX is acting strange It idles at about 1200rpm when i first crank the car and once it's had time to warm up if I stop somewhere and let it idle it runs anywhere from 500-800rpm. Any thoughts?
SILENTCARL
40
  • Jan 31, 2008
Once it is warmed up, turn off the car. Then unplug the IAC (Idle Air Control) valve on the throttle body. Start it back up, and adjust the idle to 850-1050 rpms (or your desired idle) with the adjustment screw. Then Shut the car off, and plug the IAC back in and drive. That should do it.
If not post back so we can try to help you some more.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Jan 31, 2008
  • Jan 31, 2008
Leave it alone, that's how it is supposed to work...
T
tim_lemmy
94
  • Feb 1, 2008
So my car is supposed to idle low enough that it sputters? I don't think so. no car that i'm aware of is supposed to do that
SILENTCARL
40
  • Feb 1, 2008
Just raise the idle like I mentioned to get away from the too low idle. Stinger is right, it should start off at 1500 or so, and idle down to 800. But 500 rpm and hunting idle makes me think your base idle is set too low.
Stinger
7,754
24
118
Feb 2, 2008
  • Feb 2, 2008
Did you say it sputters in your first post? No. You just said it idles down to 500-800 (which implies you don't know how low for sure). Don't be a smartass.
T
tim_lemmy
94
  • Feb 5, 2008
Sorry. I wasn't trying to be a smartass. I just ass/u/me d that any car that idled at 500 rpm would sputter and die.
SILENTCARL
40
  • Feb 5, 2008
Did you / have you tried just setting your base idle yet? If it doesn't work I have a few more suggestions...
T
tim_lemmy
94
  • Feb 6, 2008
I haven't had a chance I've been teaching karate at night because the main instructor is on vacation I plan on doing it this Friday
Stinger
7,754
24
118
Feb 7, 2008
#10
  • Feb 7, 2008
  • #10
Fair enough. For future information, many 4 cylinder cars idle between 500 and 600rpm.
T
tim_lemmy
94
#11
  • Feb 11, 2008
  • #11
the car's running fine now but now that i've adjusted the idle the check engine light is coming on
Stinger
7,754
24
118
Feb 12, 2008
#12
  • Feb 12, 2008
  • #12
Scan for codes...
J
Jimmy2Times
63
Atlanta, GA
Feb 18, 2008
#13
  • Feb 18, 2008
  • #13
If you changed the idle speed by turning the throttle set screw but didn't adjust your throttle position sensor (TPS), that's probably why your engine light is coming on. You need to adjust the sensor to return a voltage between 0.8V and 1.0V with the throttle closed.
If you aren't familiar with this procedure I'm sure you can find a write-up on here... if not let us know and I can give you the short version.
SILENTCARL
40
#14
  • Feb 19, 2008
  • #14
x2
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
