Ok, so i got my hands on one of those fancy expensive, snap-on diagnostic tools to troubleshot and run codes. The one (major) one was Low voltage TPS. I guess when i hooked it back up, I did not have the little flat blade of the tb in there right, and it was reading 0.01 . Now it is 0.98 at idle. My only question now is about the IAC. Do these things stick sometimes? I cleaned mine out with carb spray, but it works sometimes and not others. They make you turn on a/c, turn wheel, and you can watch as the iac% compensates to keep an idle. My question is, does anyone know the exact % it should run at idle?, or is it a turn kind of thing?
