I replaced my pcv so its not that i also replaced my iac so its not that and it still idles high same way. heres exatly what happends. i also only had the new iac on for about 25 miles should i have left it on? i figured since it didnt make a difference instintly then it cant be a stuck valvle like i thought. what else could it be what else can i try? how can i check to see if my mass air is bad or what about that other sensor in the elbow? also whats that black piece thats connected between the elbow and the iac? its a black box in the middle of the 2 hoses connected to it?
So here are what itsdoing.
1-when i start the car cold, it'll idle at around +1200RPM, and come down to about +800RPM as engine worms up(this is normal). as soon as you starts to drive around, it will not idle at 800RPM. But idle at +1000RPM. and stay there until i shut off the car again, and starts it back up. then it'll idle again at +800RPM, and repeats what i'v just discribed.
2-when i'm idleing at either +800RPM or +1000RPM, if I turn A/C on, then idle will come down to about +750RPM(this is also normal)
3-Either with or W/O A/C on, and regardless of idle RPM, if i brip the gaspedal in neutral, it'll stop at around +1600RPM. It'' raise RPM with this sound of air serging(I guess). and hang there for about 2~3 sec, and then comes back down to what ever the RPM was previoulsy(either 800RPM or 1000RPM. If i only give the gas until about 1100RPM, and let it go, it'll continue to rise its RPM until 1600RPM on its own. This suck azz, because....
5-Appearently, this serge of Idle is going on even when I'm driving around in any gear. Infact, i can drive around in 5th gear(or any gear for that matter) at around 1200RPM without touching gas pedal. its like having crouise control on.
6-While I'm driving around at any speed, and i disengage clutch, RPM will stay at 1400RPM. infact if i'm coasting down to stop in neutral from any speed(25mph ot 65mph), it'll stay at 1600RPM until i come to complete stop. then once i'm at complete stop, it'll stay a 1600RPM for about second, and then come back down to 1000RPM(Or 750RPM if I have A/C on.
7-While i do number 5 above, sometimes RPM will fractuate up and down between 1600RPM and 1000RPM. wen its dropping RPM from 1600RPM, it'll make sort of gerggle sound - and as soon as it hit 1000RPM, then it'll shoots back up to 1600RPM, then starts to come down, to about 1000RPM with sound and repeates itself.
You dont need a pc flash for a TB. Call accufab and act like you bought one of their plenums and tell him you have some idle issues he will help you.
