  • 2005 - 2009 Specific Tech
Idle problem
  • Thread starter Thread starter Hectorortegon77
  • Start date Start date Feb 22, 2020
H
Hectorortegon77
Colorado Springs
Feb 22, 2020
  • Feb 22, 2020
I have a 06 mustang gt stick shift and I accidentally let out the clutch too fast going from 3rd to neutral to make a turn and a I heard a big clank I thought my trans broke but I drove it the next day and it was fine but I realized that I usually shift from 2nd to 3rd to go 30mph and I would be driving at 30 mph at 1,500 rpms and after that little accident when I shift from 2nd to 3rd my car drives at 2,000 rpms I need to know what’s wrong to fix it
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 23, 2020
  • Feb 23, 2020
Sounds like your clutch plate was already worn to the limit and now it's slipping. How many miles have you done on it?
H
Hectorortegon77
Colorado Springs
Feb 23, 2020
  • Feb 23, 2020
My car has about 110k miles
E
EmmJay
96
25
28
USA
Feb 23, 2020
  • Feb 23, 2020
Does the RPMs go up in disproportion to your speed as you accelerate harder? This would indicate the clutch plate is slipping and you need to replace it. If not then there might be another issue.
H
Hectorortegon77
Colorado Springs
Feb 23, 2020
  • Feb 23, 2020
I’m sorry I don’t know what you mean by that but usually when I reach the speed limit I would shift up and then I would go whatever the speed limit is at 1500 rpms but now that I reach the speed limit and shift I have to go at 2000 rpms which makes me shift once more
E
EmmJay
96
25
28
USA
Feb 23, 2020
  • Feb 23, 2020
The only way your RPMs can change with a manual transmission is if the cluch is slipping. Otherwise, there is a direct coupling of the engine and the rest of the drive train that will not allow the RPMs to change at any given speed in any given gear.
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 24, 2020
  • Feb 24, 2020
If it's still on the original clutch it's done very well to go that far. Time to replace it.
H
Hectorortegon77
Colorado Springs
Feb 24, 2020
  • Feb 24, 2020
What do you suggest I do?
H
Hectorortegon77
Colorado Springs
Feb 24, 2020
  • Feb 24, 2020
By the way my third gear doesn’t pull as hard as it use to
E
EmmJay
96
25
28
USA
Feb 24, 2020
#10
  • Feb 24, 2020
  • #10
I suggest taking it to a reputable repair shop and have them check it out. My guess is you have a worn clutch. If it isn't as fast in 3rd gear then it isn't as fast in the other gears too. A good shop will sort out the problems for you.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
