I have read the past posts and cannot find the answer. the past posts talk about the iac, tbs, collant tems sensor, timing and base idle. the tbs, iac ant the coolant temp sensor have been replaced, along with the base idle and the timing being adjusted. the car still dies when I start it after it has sat for around 5 hours. If it sits for anyamout of time after that it will not die and stay running. I think that the "memory" in the computer is being deleted after some time, but it is not my battiery because my radio always has the same setting and the car cranks with no prolbems. also anyone got any ideas or thoughts on how to fix my idle prolbem?
Also, what shoud my idle speed be set at? I did the idle like this article says.(http://www.muscularmustangs.com/idlereset.html)
