OK well, as I mentioned on a different thread, once I finally got my header leak under control I was feeling like I was on a roll and decided to tweak my timing and carb and hook up my tach and stuff like that. Well, I settled on 16 degrees BTDC and ended up leaning out the carb just a tad, my question is what if anything can be found out about if it is running at peak or not by knowing the RPM's now? I mean the car sounds excellent, it has never felt better either. Both idle and acceleration felt great. Here is what the tach had to say for my 3spd manual. Intitial start idle was at 650rpm's and once it hit operating temp it was at around 850rpm's. 2nd gear wound up to about 3800rpm at 60mph once I hit the on ramp and when I hit 80 in 3rd gear it was cruising at about 2700rpm. Does that sound about right or efficient? I have no idea what the engines redline would be, but I always imagined my highway RPM's would be higher than that before the tach and rarely brought it over 70 but it would seem I can go even faster with little or no worry (not that I want to though with drum brakes).
I know all my newer stock cars idle at more like 500, but there isn't much I can say my old car and my newer cars ever have in common, and let's face it, at least with the Mustang, stock settings are always enimic and geared more towards economy than they are performance.
