Electrical Idle Stumbles When Radiator Fan Turns On
cjcoburn
54
Denver, CO
No...I have not forgotten about this problem; been living with it everyday still. :O_o:
Just tonight I installed a reman'ed OEM Motorcraft alternator and the problem persists. Since the car was warmed-up I could get the cooling fan to kick-on pretty frequently by running the A/C. To rule-out the relays in the CCRM (to some degree) I unplugged the fan and ran the A/C again long enough to have the fan commanded on -the engine didn't stumble.
So in spite of previous testing conclusions I plan on replacing the fan. But first I'm going to make sure the wiring to the fan is all good.
More to come and quicker than in 2 years (sheesh).
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,807
499
164
Houston Texas
FWIIW, for the Mustang GT the low speed fan runs with the AC is on (not the high speed fan). The only time that the high speed fan is if the AC head pressure is above a certain level.
So turning the AC on and off is only testing the low speed fan.
If interested in testing the high speed fan then consider using an advanced ODB2 scanner with two way communications to "command" the high speed fan to run.
ForScan ODB2 scanner w ELM327 USB
https://www.stangnet.com/mustang-forums/resources/forscan-odb2-scanner-w-elm327-usb.57/
Howto perform charging system voltage drop test
https://www.stangnet.com/mustang-fo...perform-charging-system-voltage-drop-test.56/
If this were my car I would be performing a voltage drop test between the fan ground and battery negative on low speed and high speed. Then repeat the test on the power lines and battery positive.
Repeat the voltage drop tests between the alternator case and battery negative as the fan is being cycled. What you are looking for is IF the voltage drop suddenly goes up when the fan draw kicks in. Repeat the measurements between alternator B+ and battery positive.
This should also be cross checked against the voltage at the alternator and battery to confirm that the charging system voltages are stable.
If all of the voltage drop measurements are low, then the only reasonable conclusion left is that the fan is drawing way too much power.
cjcoburn
54
Denver, CO
Using FORScan I found out that the low-speed fan is not working. I can hear the relay energize but the fan does not run; zero volts at the fan connector's low-speed terminal.
Later I will try the voltage-drop tests you recommended on the high-speed and ground circuits.
As for the part where the voltage at the alternator and battery are checked for stable voltages, they do drop when the fan kicks on but come back up and are stable after a second.
More to come. Thanks again.
wmburns
Aug 14, 2009
5,807
499
164
Houston Texas
Many cooling fans use a ballast resister in series with the low speed fan to drop the voltage so that the fan runs slower. If this were my car I would rule out an "open" ballast resister.
If on the other hand there is zero volts at the low speed terminal with the connector disconnected, then in this case think "bad CCRM".
cjcoburn
54
Denver, CO
Haven't done the voltage-drop tests yet but I figured-out why the low-speed fan was not coming on. Turns-out the high-current fuse box had been removed. The wires were just cut, folder back, wrapped in electrical tape, and then put back into the plastic harness which had its end wrapped in electrical tape. From what I can tell, this box just holds a 30A fuse that's between the CCRM and the fan motor.
What's on the left side of the picture on the front of the strut tower circled in blue is missing in my car.
628912
So I wired-in a weather-proof fuse holder. The low-speed fan now works as it should. When it runs the engine idle does NOT stumble. High-speed fan still does stumble the idle.
I did end-up getting that ELM327 USB dongle and ForScan. Had some fun with that, especially the bi-directional controls. Wish it could do just a bit more like show live data while activating some of the bi-directional controls. But for the price I'm not complaining -still a geat deal. Thanks for the tip on that.
As always, more to come...as life permits.
Thanks!
Thread starter Similar threads Forum Replies Date
Rynb15 Engine mid/high rpm stumble, idles good. Fox 5.0 Mustang Tech 16
A Engine 1998-Stumbles when fan kicks on SN95 V6 Mustang Tech 1
B 1990 Gt Auto, Rich At Idle?, Stumbles With Throttle? Fox 5.0 Mustang Tech 13
Y 99 Gt Power/idle/rev/vibration Issues 1996 - 2004 SN95 Mustang -General/Talk- 2
Amber Midkiff Help! Misfiring, Stumbling, Rough Idle, And Loss Of Power SN95 4.6L Mustang Tech 5
ram360 Low Idle, Stumbling When Driving 1994 - 1995 Specific Tech 7
Gtwo P0340 and a stumble coming off idle. SN95 4.6L Mustang Tech 2
S Idle Issues and Stumbles in low rpm 1994 - 1995 Specific Tech 1
K Stumbling Idle at Startup 2005 - 2009 Specific Tech 2
AIbandit RPMs Stumble/surge (not idle) Fox 5.0 Mustang Tech 19
notch351 voltage drain at idle and stumble help Fox 5.0 Mustang Tech 2
T Need some help (Speedometer and clutch cable, low idle, stumbling) Fox 5.0 Mustang Tech 6
7 mass air conversion has off idle stumble 2.3L (N/A & Turbo) Tech 0
GearHd6 Slight Stumble Off Idle (Normal?) Fox 5.0 Mustang Tech 6
GearHd6 Slight Stumble Off Idle Fox 5.0 Mustang Tech 1
1 Off Idle stumble. Fuel prob or vacuum leak? Fox 5.0 Mustang Tech 0
ponycar17 2.3 Stumbling at Cruising RPM and Idle 2.3L (N/A & Turbo) Tech 3
S Off idle stumble Classic Mustang Specific Tech 24
8 Update on erratic idle and stumble Classic Mustang Specific Tech 4
8 Erratic idle and stumble all of a sudden Classic Mustang Specific Tech 10
S Car stumbles at idle 1994 - 1995 Specific Tech 5
1 car stumbles from idle to 2500 Classic Mustang Specific Tech 8
brentwoodboy Missing/Stumble At Idle, Not a Surge...Whats a PIP? 1994 - 1995 Specific Tech 7
LT1Killa Help me fix my stumble off idle. PLEASE! Fox 5.0 Mustang Tech 3
D HELP!! car idling like crap and stumbling Fox 5.0 Mustang Tech 3
O Stumble during rev, idle weirdness Fox 5.0 Mustang Tech 3
brentwoodboy Replaced 02's, Still Stumbles At Idle, also CE light. MAF? 1994 - 1995 Specific Tech 0
M High idle, stumble on accel, now won't start 1994 - 1995 Specific Tech 1
J Idle issue still!! Replaced several parts.. looking for more ideas!! Fox 5.0 Mustang Tech 11
G 1998 3.8L V6 overheating at idle, gauge doesn’t go up. SN95 V6 Mustang Tech 0
bmgstang Need help with tune high idle Digital Self-tuning Forum 2
S Another Idle surge post with microsquirt Digital Self-tuning Forum 2
H Engine Tach goes to zero,engine goes to idle on 87 GT Fox 5.0 Mustang Tech 9
D 1994 Mustang Gt erratic idle 1994 - 1995 Specific Tech 1
A New fox owner, idle issues need some advice Fox 5.0 Mustang Tech 20
Mixveez Bad idle and dying in neutral. Fox 5.0 Mustang Tech 5
C Microsquirt tuning and surging idle problems Digital Self-tuning Forum 7
L High Idle and Hanging RPM. Tried everything, still no fix. SN95 4.6L Mustang Tech 0
J 2000 GT Idle/Running Issues SN95 4.6L Mustang Tech 6
9 Air Condition Idle up with 2-speed fan (MSPNP Gen 2 V1.2) Digital Self-tuning Forum 8
maisonmays22 Cannot figure out why my engine dies at idle Digital Self-tuning Forum 11
R Engine My 95 gt idling rough 1994 - 1995 Specific Tech 5
MSTNGGRL1995 Rough, loping idle and random attempts to die 1994 - 1995 Specific Tech 1
T Engine Foxbody idling surging and stalling Fox 5.0 Mustang Tech 10
B Slight surging idle issues Digital Self-tuning Forum 14
K Engine New Built Engine - Rough Start and Idle Surge Fox 5.0 Mustang Tech 3
G Engine Idle fussy only when 1st starting Fox 5.0 Mustang Tech 7
S Megasquirt PNP2 460SBF startup/idle issues Digital Self-tuning Forum 9
W 97 Mustang GT to 2011 Crown Vic Swap 95k Miles (Knock at idle) 1996 - 2004 SN95 Mustang -General/Talk- 1
Michael sommers 02 mustang gt auto knock only at idle in gear. SN95 4.6L Mustang Tech 2
