I have a 66 coupe with a healthy 289 (11.5~1, 351 heads,540 soild lift cam, torker intake and 650 mighty demon carb. I have been running this on Sundays and have approximately 400~500 miles on it after restoration. The problem I have is the idle will surge (from 950 to 1500 rpm) after I jump on it and let it return to idle (when sitting still). I think it is the fuel pressure regulator or fuel pump. I have a Holley red pump and regulator setup. I set the pressure to 6 psi with engine running and I noticed when the idle surges the regulator is reading 4 1/2 to 5 psi. Short of pumping fuel into a container and timing the amount pumped to determine rate, how do you properly suggest I determine fuel pressure output of pump? It should be possible to deadhead it prior to the regulator with another gauge to determine pressure output, and if it is above what I am running I could assume it is not the problem. Has anyone had this type of problem and do regulators fluctuate this much due to weak spring or spring fatigue? I would rather spend $25 on a regulator than $100 on a pump to resolve problem. Any suggestions? Brian
