  • 1994 - 1995 Specific Tech
Idleing problem!
  • Thread starter Thread starter xYoung347x
  • Start date Start date Jan 10, 2004
xYoung347x
382
  • Jan 10, 2004
Well I got the motor to turn over but it sounds like ASS! The best way to describe is, a ****ed up lawnmower that you keep pulling on to try to start up and dies on you and its 10x louder. the car is making a loud poping noise, it is backfiring, it will not hold idle, and It will revup and die. It sounds real aweful. It would jump to like 3k rpm and dies. I think its the distributor, I think Im stapping it wrong. I stabbed the distributor like 20 times... same result. I put number 1 at TDC on the compression stroke and put the distributor in with the rotor pointing twoard number 1 on the cap. If I advanced or retarded the timing it would not do anything. I have checked the vacum lines and the firing order. It has a new starter, cap, rotor, distributor, coil, plugs and wires. Why wont it idle?
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jan 10, 2004
  • Jan 10, 2004
turn the motor over by hand till the 10* mark is lined up with the timing pointer....then pop the cap off...where is the rotor pointed??...also did you remove the spout before doing the timing??
Anthony
DavidF
158
Ventura, Ca
Jan 10, 2004
  • Jan 10, 2004
You might be 180 degrees off. Double check TDC.
xYoung347x
382
  • Jan 10, 2004
We would feel #1 for the compression stroke and then put the balancer to 0 on the timing pointer. When we stabbed the distributor I would point the rotor towards #1 on the cap and I did this like 20 times but still no luck.
StormTrooper
34
Mississippi
Jan 10, 2004
  • Jan 10, 2004
what block are you using i have heard of some lincoln and merc blocks doing this---also is the filter under the intake(in the back) clogged or missing?
mytight95
2,605
Dothan,Al
Jan 10, 2004
  • Jan 10, 2004
did you put in a cam with a 351 firing order by accident, if you do not know then what kind of cam is it.
jason
a lot of performance cams have the 351 firing order, they say it is more efficient.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
Fox Possible timing not sure
  • K1tha1
  • Apr 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
AeroCoupe
