Idling low then dying randomly
  • Thread starter Thread starter gradient
  • Start date Start date Aug 1, 2004
G
gradient
52
  • Aug 1, 2004
my 95 GT 5spd with only 46k miles on it has acted up a bit lately..
it's completely stock btw..
i was waiting in line at a car wash, and had turned off my car while i waited. after about 10 mins, i started it back up, and pulled forward, entered my code, and turned the car off again. waited another 5-10 mins, then started it back up when it was finally my turn to go in.
this time, the car idled really low, then died as i was trying to put it in gear. started back up, and it died while still in neutral. i finally got it to go forward by revving it really high before it had a chance to die (like 2-3k rpm).
after the wash i started it back up and went on my way no problems. i also drove about 150 miles the next day with absolutely no troubles at all.
the only problem with the car atm is the clutch pedal. it is VERY stiff. i have read about cable binding and routing problems. is there a chance that the pedal was causing the idling and dying problems?
sorry for the long post.. thanks.!
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Aug 1, 2004
  • Aug 1, 2004
You probably need to clean the IAC and adjust the idel.
http://www.50tech.com/articles/display_article.php?catid=8&id=4
HISSIN50
34
129
Aug 1, 2004
  • Aug 1, 2004
welcome to the boards. you will notice that there is a 94-95 sub forum - those guys are up on the ideosynchratic stuff with the SN's.
if the car only did this once, i would not read much into it. with a few cars of mine, ive noticed that if they are hot, shut off, started back up within a few mins, they idle funky (idle low). if i hold the gas for a few seconds, they pick up. or i just drive off.
i think i would go insane trying to track down suck an intermittant issue, so i prefer to deal with it.
you could pull codes and see if one was tossed (some codes, esp intermittant ones, can be stored w/o setting the CEL). sometime, you might want to clean your EGR valve - if it stuck at idle, it would degrade the idle or kill the car. a lot of SN guys have ditched it (or moved it and fixed the pintle in the bore).
random thoughts. good luck.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
