If i go turbo...what else will i need?..the kit im looking at is complete..I already have 42lb injectors,255lph GSS340 fuel pump,adjustable FPR,Im getting a comp blower/nitrous cam,Abaco DBX 95mm MAF sensor, The car is an AOD im having a custom stall speed convertor made..And now if i go turbo i will probably put it 327's or 3.55's what gear do you think?...The car also has GT40 heads..with a 5 angle valve job,bronze valve guides,new stainless exhaust valves,Teflon coated valve seals and Trick flow valve springs..Im going to get a Trick flow track heat intake or Holley system max, I have a BBK 70mm TB....Im going to limit the boost to around 7 psi for now its a 87 stock short block...What do you think I will be able to run with this? It is in a convertible and it is a auto car......Oh yeah im getting a good Air fuel gauge too...
