If you are are installing an aftermarket water temp gauge...
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
And want to put the stock one in the water neck here is a tip. Most people I talked to said that it would break and it will if you dont do it right. I drilled a 1/2 hole in the water neck and tapped it and started putting the stock sender in but it was kinda hard to turn and i knew I would crack the neck if I put it in any more.
So this is what you do.
You re-thread the sender too. Voila. Now it fits and wont break.
