ok here we go again, and yes I have searched, I just wish more people post when they have actually solved there problems .
last time I had a bad PIP in the distributor, changed it and it was fine fore a couple of days
, now surging, stalling sometimes it would cut out fore like a split second then go again, and it s hard to start it cranks ok but sometimes it wont fire if you don't step on the gas
now I have good fuel pressure 36 psi at idle, new IAC new ignition module all the grounds seem fine, new plugs, checked the wires fore spark all are good so
the only 2 sensor not changed yet are the TPS and the air charge temp sender , but I doubt those can cause these symptoms, but then again I wouldn't now
I also have a chip with the egr and smog pump deleted, the car was idling and running fine before all this crap ,sorry fore the long post :Zip2:
