Ignition Question....
  • Thread starter Thread starter OurBlue95GT
  • Start date Start date Jan 30, 2010
OurBlue95GT
New Hampshire
Jan 30, 2010
  • Jan 30, 2010
Hi All.. Been awhile since I posted here... Anyway, I've got a question...
Haven't given it much thought until now, since spring is coming around the bend, but before I put the Stang up for the winter I was pulling in to my driveway, about to shut it off and the ignition wouldn't shut off. It would turn, but not the actual ignition ( makes sense?)
I unhooked the battery to shut the car off, hooked it back up and was able to turn the ignition over and start it, but still not shut it off...
Has this happened to anyone before? And is it as simple as getting a new ignition switch?
88stang88
5 Year Member
Apr 28, 2005
309
St. Louis,MO
Jan 30, 2010
  • Jan 30, 2010
It sound's like a ignition switch being that you can not cut the power to the motor by turning the key off. Never heard of this happening much on Mustang's but it's worth a shot at replacing and if that doesn't work im pretty much in the dark with the rest of ignition components.
RIO5.0
6,892
N.H.
Jan 30, 2010
  • Jan 30, 2010
It's not uncommon for these to take a dump...majority will spin around and start without the key...sounds like your is reverse??
I would say a new ignition is in order. A locksmith can key it so your door & trunk remain the same.
HISSIN50
34
129
Jan 31, 2010
  • Jan 31, 2010
It can also be a linkage issue (going to the switch).
RIO5.0
6,892
N.H.
Jan 31, 2010
  • Jan 31, 2010
Good point...forgot about that...
OurBlue95GT
New Hampshire
Jan 31, 2010
  • Jan 31, 2010
Thanks guys!!!
I still haven't taken a look at it, but I did dig out the book, lol. I hope to take a look at it sometime this week. We shall see....
toyman
1,944
54
79
Vernon BC
Jan 31, 2010
  • Jan 31, 2010
I wouldn't have thought that would work as the alternator is still working. Was it the positive lead that you pulled from the battery or both? I would have just pulled the coil wire. Learn something new everyday.
desertcox05
379
south atlanta
Feb 1, 2010
  • Feb 1, 2010
12v at the battery vs 20,000v at the coil.
you choose how you might be shocked.
OurBlue95GT
New Hampshire
Feb 1, 2010
  • Feb 1, 2010
I pulled both, to make sure.. My husband had said to pull the coil wire.. I was leary and took the easier root...
LOVE the color of your car!! LOL
HISSIN50
34
129
Feb 1, 2010
#10
  • Feb 1, 2010
  • #10
While perhaps seeming the simplest, pulling a battery cable can cause an electrical spike that can wipe out electrical components.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Feb 1, 2010
#11
  • Feb 1, 2010
  • #11
It ain't the volts that hurt, it's the amps. Read up a bit on Tesla coils, they can put out millions of volts and they barely tingle.
HISSIN50
34
129
Feb 1, 2010
#12
  • Feb 1, 2010
  • #12
A leaky plug (or coil) wire will make you jump of you're grounded. There's no real reason to even chance it since there are much better ways to shut the vehicle down quickly.
desertcox05
379
south atlanta
Feb 2, 2010
#13
  • Feb 2, 2010
  • #13
maybe pulling the coil power wire instead on the battery
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
