Over the weekend, a friend asked me to help install his Pertronix 2 ignition. I stopped by his house today and looked through the instructions. His car is a '68 Mustang (same as mine) so I checked to see if I could find a resistor wire or a ballast resistor. I found no ballast resistor so I checked and found a pink resistor wire on the back of the ignition switch. I told him we'd have to bypass the wire so the coil would see 12 volts, but when I checked it with a mulitmeter to show him it only got 9 volts or so, I tested and got 12 full volts from the wire with the key on. Anyone know why that would be? I don't have time to do the install until the weekend, but if I don't have to screw around with the wiring I'd rather not. Anyone else find this? Anyone just plug in a Pertronix 2 and Flamethrower coil without bypassing the resistor wire? Would it even start?
