i've read about the fuel pump cut-off, and the battery cut-off but i was thinking if there's any way to get a switch to engage the ignition? like you have a switch wired into the ignition switch that you'd have to flip before turning the key. and it may sound dumb, but i was thinking of just hiding it out in the open. since i have an LX that flog light switch under the headlights is just blank. so if i were to get a GT replacement switch for it, make it look like the LX does and wire that to the ignition...
good or bad idea?
P.S. i could even go and wire the fuel pump cut-off to that instead of the ignition..
good or bad idea?
