ignition
  • Thread starter Thread starter mustangderek22
  • Start date Start date Dec 29, 2005
1 of 2 Next Last
M
mustangderek22
40
New Ringgold PA
Dec 29, 2005
  • Dec 29, 2005
i got a daily driver 89 mustang lx....i`m looking for a good msd ignition set up..mainly looing for a coil and box can anyone help?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2005
  • Dec 29, 2005
MSD = May Suddenly Die... I wouldn't have one unless it was free.
The stock ignition is good up to 400 HP without NO2 or forced induction. If you don't have them or plan to get them, spend your money elsewhere.
bill302
2,131
alabama,gadsden
Dec 29, 2005
  • Dec 29, 2005
click on links below.
http://www.jegs.com/webapp/wcs/stor...&resultCatEntryType=2&searchTerm=msd+ignition
http://store.summitracing.com/defau...eywordSearch&DDS=1&N=115&target=egnsearch.asp
bill302
2,131
alabama,gadsden
Dec 29, 2005
  • Dec 29, 2005
jrichker i have a msd coil on my stock 95 GT (paid $55) is it a waste of money, i replaced stock thinking i would increase volts creating bigger spark to help detonation and increase mid range RPM power and smoother idle. what is your opinion, (i'm guessing the stock coil puts out enough volts to do all this ,right.)
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2005
  • Dec 29, 2005
You got it...
The detonation or pinging at cruse, 1700-2500 RPM, may be due to a malfunctioning EGR valve. That's my problem. I still haven't chased the electrical problems that have caused it.
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Dec 29, 2005
ok, so if im reading this right, i should have close to around 400 at the flywheel before the juice. so i wont be wasting my money. good to know.
bill302
2,131
alabama,gadsden
Dec 29, 2005
  • Dec 29, 2005
jrichker said:
You got it...
i don't have any pinging problems.only problem i have is a small rough idle(i about have this worked out) i believe this is normal in the 5.0s. and some small backfiring at startup when it's cold out don't know if it would do it if i drove it everyday i only crank and/or drive it about every 2-3 weeks, whats your opinion (normal)?
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Dec 29, 2005
  • Dec 29, 2005
I woudn't use MSD (Except for Wires) if someone paid me....Alot of there stuff especially the 6A and 6AL boxes etc. are old technology. I used to work in a performance shop and the amount of MSD products that came in under warranty was just ridiculous. I used to run MSD, and I finnaly had enough and started running Crane ignition components and have not once had a problem. Currently I'm running Crane's new Electronic Distibutor, HI6 Box & PS92 Coil and I have been very impressed.
Shon
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 29, 2005
  • Dec 29, 2005
I wouldn't even use their wires (bad experience)
I got my box used and for a resonable price this winter. I haven't driven the car yet. All I know is the idle is now more stable than when it was.
Curse
791
El Paso, TX
Dec 29, 2005
#10
  • Dec 29, 2005
  • #10
Again for every one person who hates MSD, someone else loves it.
I have had no problems with my MSD stuff at all.
M
mackey
1,284
Beverly, Massachusetts
Dec 29, 2005
#11
  • Dec 29, 2005
  • #11
I hear good things about the high end MSD products such as the Digital 6. I've heard more negative comments about the 6al and 6a.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Dec 29, 2005
#12
  • Dec 29, 2005
  • #12
I totally agree, everyone has an opinion. Opinions are like noses because everyone has one. And to be honest, I haven't tried them since 1996 so maybe things have changed.
Currently it's Crane or Accel products for me.
Curse
791
El Paso, TX
Dec 29, 2005
#13
  • Dec 29, 2005
  • #13
The digital 6 is a great box, especially if you are running nitrous.
Busted07
Nov 15, 2005
#14
  • Dec 30, 2005
  • #14
Man, i knew i wanted crane stuff, and this kinda helped me along. The only reason i wanted MSD in teh first place was because of all of the plug and play stuff that was available. like the timing retard and junk... anyone know if crane has or is coming out with that stuff?
Black Sun 5.0
1,337
L.I., N.Y.
Dec 30, 2005
#15
  • Dec 30, 2005
  • #15
Not everyone has a nose. Just look at Michael Jackson.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Dec 30, 2005
#16
  • Dec 30, 2005
  • #16
Crane has Timing retard control. You have to mount it in the cockpit and run some wires to the box, but it has to be similar to the MSD stuff (I haven't compaired the two)
Summit has all of the crane stuff on their website
Busted07
Nov 15, 2005
#17
  • Dec 30, 2005
  • #17
actually, now that i think about it, i have to get the accessories for either a WOT switch / window switch, for the juice later on
rd
3,316
63
109
Ocean Springs MS
Dec 30, 2005
#18
  • Dec 30, 2005
  • #18
Interesting stuff here.
I have a Jacobs on my Capri that I installed in 1986 or so. It has worked perfectly ever since. It did give me at least one mpg improvement, and the car will still get 21 mpg. Couldn't get it out of the 15's though...
However, their phone tech help then was awful, and has gone downhill over the years. The current guys don't know anything about the older ones. So I probably wouldn't go there.
I was surprised when my my 82 went 12's on the motor with a 70-something Duraspark box plugged into it.
It also seems to handle the 7.80 sprayed runs in the eighth mile with the 100 shot. I do have Taylor wires and swear by them.
Been thinking MSD Digital 6 to see if it improves anything.
Busted07
Nov 15, 2005
#19
  • Dec 30, 2005
  • #19
a buddy of mine put a newer jacobs box on his thunderbird (he had an allen engine development S/C on it) and it never worked right. he put the stock ignition back in, and everything was fine. they sent him a new one, and it did the same thing. so he just kept the stock stuff, and now that makes me leary to buy anything from them. and thats surprising for how much thier products are
fiveohwblow
Official Member
2,169
145
155
Dec 30, 2005
#20
  • Dec 30, 2005
  • #20
I just got an MSD 6Al box for Christmas and installed it with the MSD TFI coil, and to tell ya what, it helped surface a problem with my FRPP 9mm wires which are brand new. The number 4 wire was arcing so bad WHILE MOUNTED to my plug I could hear it popping over my supercharger and exhaust inside my car! With the stock components the problem didnt surface until 5k in the RPM range. If you ask me, this is the PERFECT example as to a benefit of an aftermarket ignition. The reason I got the MSD was simply that very many people run their ignitions which has to be a testament. I have subscribed to 5.0 Mustang mag since Nov, 1997 and in a recent article of the shootout they do with 10 vehicles to see what the best mustang thier readers own 9 out of 10 ran MSD. Says something for its rep. As far as the tech being old, nothing on my car is worthy of a new tech magazine.... The SCT is the only thing that is amazing, but even that is integrated with the antiquated A9L. I know new tech can improve old, but by what margin or what percent. If you want MSD, get it. I love mine.
1 of 2 Next Last
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
